Electric or pulley water pump?
Discussion in 'Technical' started by Gmur, Jan 17, 2018.
  1. Gmur
    Gmur Member
    Vancouver BC
    1970 Ford Maverick
  2. 71gold
    I loved the E-water pump I had on my 347...:thumbs2:
  3. rthomas771
    I love the elect. H2O pump on my 289
  4. Hotrock
    Munroe Falls, Ohio
    Do you have power steering?
    Why do you need to replace your front accessory kit?
  5. Gmur
    Gmur Member
    Vancouver BC
    1970 Ford Maverick
    The engine in my car is from a '91 thunderbird. When the previous owner installed it he didnt have quite enough money to replace it. So he cheaply fabricated some brackets to make it work. Like a solid mount idler pulley where the power steering was. The alternater bracket is super hokey. Everything.flexes and makes the belt squeal.
  6. airford1
    airford1 Member
    San Dimas, Ca
    The mechanical pulley pump will out last the electric, but the electric will pump more water at idle.
  7. Krazy Comet
    Dismal Swamp
    Be sure the pump(s) will fit...
    AFAIK the '91-'93 T-Birds, '94-'95 Stang and Sploders use a different timing that requires a specific pump...
  8. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I've got a Moroso electric pump I've been using but my stuff is torn apart for now. When it goes back I will use a belt driven pump.
  9. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    I like my elect water pump on my 349 IMG_1514321014626[1].jpg IMG_1514321014626[1].jpg IMG_1514321014626[1].jpg
  10. Gmur
    Gmur Member
    Vancouver BC
    1970 Ford Maverick
    Sounds good. Thanks for all the replys!. Ill do some more research. But i am leaning towards electric.
