electrical drain
Discussion in 'General Maverick/Comet' started by bigkat79, Jun 24, 2008.
  1. blugene
    blugene Senior member
    Sounds inconclusive to me. The alternator should be full fielded with the regulator disconnected to see how many amps it's capable of putting out. A good tester machine will have an amp probe. It can be used to see how many amps certain componants are drawing when used, like the headlights.
    I once had another Ford that had a bad dimmer switch. It affected the headlights, but i'm not sure if the Mavs are grounded thru there or not. Maybe you have a headlight switch problem :huh:
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Ive had the same problem w/ headlight draining battery before (was the switch also)
    If they didn't disconnect the regulator, they didn't help you out any at all.
    I've had alternators die the same day I put them on and they tested good.
    Yours still could be bad, but work at an idle, just not at higher RPM, or it could be the regulator as stated above.
    Just out of curiosity, is your alternator belt tight?
  3. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    belt is tight, all seems to be fine now. i have driven it with the lights on and everything, but now the alt. light stays on all the time. fires right up without a problem and stays running though.
  4. PaulS
    Try doing this:
    disconnect the battery wire at the alternator and connect a light between the wire and connector on the back of the alternator. If it lights up then you have at least one of the six diodes blown. Time to replace the alternator.
  5. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    do i just use a regular 60watt household bulb?
  6. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    He means a 12v test light.:)
  7. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    <-- Subscribes to this thread. :coffee:
  8. PaulS
    I would recommend a tail or brake light in a used socket. That way it is brighter than a test light and it takes more power to make it work. Either way if there is enough current to light a lamp you have a blown (shorted) diode. That will drain a battery fast!
  9. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    today i hooked up an actual tester to it and found out the battery is fine, but the alternator or the coil is bad. so im soaking some bolts with pb blaster so i can get the alt. off and replaced and im going to go ahead and get the coil too depending on how much it is.
  10. rayzorsharp
    The coil is not going to drain your battery.
  11. Andysutt
    Conway Arkansas
    1972 Comet GT
    I've seen it happen, but not on a factory setup.
    Only when the wiring has been messed with and theres a short in the power wire or its on all the time :)
