electrical problem
Discussion in 'Technical' started by 1Crazy1, May 19, 2012.
  1. rthomas771
    http://1bad6t.com/Maverick/repair/chassis_electrical_05.html
    When I replaced my turn signal switch I had an intermitting "No Left Turn Signal" issue. I figured out after I used the left turn signal then the left brake light would not work. If I used the right turn signal last...then the brake lights will work like they should. Evidently my new turn signal switch is not defaulting back to the electrical neutral position when it is in the physical neutral position. Now I try and remember to manually turn on the right turn signal after using the left turn signal to have both brake lights working.
  2. 1Crazy1
    1Crazy1 Member
    Los Angeles,CA
    Thank you for the link. Printed wiring diagram.Now to clean wires so i know what i'm looking for.Again thank you.
  3. rthomas771
    GoJo hand cleaner works good for that...plus, if you play your cards right, your hands might smell like an orange when you get finished cleaning.
