Engine Electrical Help
Discussion in 'Technical' started by Wolf Mcbee, Aug 6, 2015.
  1. Krazy Comet
    The was a seat belt interlock in '74, but probably 99% were disabled by 1975...
    Search 1974 seat belt disable, should find all the info...
    Wolf Mcbee likes this.
  2. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    Alright sweet thanks!
  3. Krazy Comet
  4. rthomas771
    DELETING INTERLOCK FUNCTION
    Locate the emergency start override switch (under hood) and remove the 4-wire terminal connector attached to it. Cut the No. 32 circuit (RED/LT. BLUE) wire and No. 33 circuit (WHITE/PINK DOT) wire as close to the connector as possible. Using a butt connector, splice the two wires together and tape the splice to waterproof it.
    Krazy Comet and Wolf Mcbee like this.
  5. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    Thanks! Might have to get down to it today
  6. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    Which wires? For the solenoid or alt.? As for alt upgrade I did large case 1 g. 100 amp. $45 rebuild off ebay. The guy was great
  7. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    The solenoid and nice, I finally found a 145 amp alt for $80 on eBay
  8. bmcdaniel
    LOL, don't mind us, we're just babbling on.
    That's what happens when you get old....
  9. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
