Engine :First Start
Discussion in 'General Maverick/Comet' started by lika, Sep 28, 2009.
  1. sierra grabber
    sierra grabber Certifiable
    northern nevada
    most engine rebuilders suggest to get it up to 2k rpm for 20min the first time you fire it off. dont know if that motor is fresh or not, but if so you may want to do that before running it too many times? sounds good though, ought to be a kick to drive!
  2. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    thats much better with the headers on it you had me freakin out before without the headers and it sounds great.it should kick a$$.
  3. lika
    lika Señor Comet
    IA
    comet 71
    ho yeah it's much better now !!!!!!!!
    I will do that!!!
    The engine is not rebuilt just the heads with new lash caps
    that's it!!!!
  4. scooper77515
    The 20 minute breakin is only for new cam and lifters if flat tappet.
  5. lika
    lika Señor Comet
    IA
    comet 71
    The first time I was scared because the sound was very loud:rofl2:
    just like bradleygt say:
  6. lika
    lika Señor Comet
    IA
    comet 71
    :idea:HOOOOOOO ok (y) copy that
  7. scooper77515
    Yeah, if you are running the same cam and lifters, and just swapped heads and other parts, you don't need the 20 minute breakin. That is just to get the lifters to "lap" to the cam.
    But if you have roller lifters, you still don't need to do it.
    Good thing too. It is one of the most stressful 20 minutes of your life. It has to start up pretty quickly, and go straight to 2000 and alternate rpms periodically but keeping them up a bit.
    When I did mine, I accidentally left a couple pieces of paper towel in the intake holes in the heads (to keep crud out of them while I did the work) so I had all kinds of flaming paper coming out for the first few seconds!!!
    Just like your first startup...I would have liked to see THAT at night...
  8. lika
    lika Señor Comet
    IA
    comet 71
    The good thing is that nothing alse happened (y)
    I'm glad that My engine works fine :dance:
  9. sierra grabber
    northern nevada
    yep that and making sure the assembly lube is cleared out of the bearing surfaces for the next time you start it (which happens within the first couple mins). sounds like you didnt need it so dial it in and ride that bad boy around!
    LMAO!!!! cant say i haven't had a few things happen too, but still funny:yup::rofl2:
  10. lika
    lika Señor Comet
    IA
    comet 71
    idling high
  11. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
  12. lika
    lika Señor Comet
    IA
    comet 71
    transmission
