Engine is impossible to start
Discussion in 'Technical' started by Izyk, Dec 14, 2021.
  1. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    Agreed, same here. You have spark, so that's not the problem. You've quadruple checked the timing; that's not it. And you're getting gas. I still there is a mechanical problem. A cold compression test won't take that long. You'll get a chance to see what the plugs look like, too. The 250 is durable, but not immortal. An engine with internal damage "can" sometime rotate fine and not give any external indications of failure.
  2. Izyk
    Izyk Member
    Ohio
    1970 Ford Maverick
    well I just tried changing the plugs and it’s still backfiring out the carb like it’s 180 out
  3. ike72com
    ike72com Member
    Charleston SC
    Redo
    1. put piston on TDC
    2. Pointer should align with crankshaft tdc. (You may have to nudge crankshaft for perfect alignment.)
    3. Rotor gotta align at #1 on cap.
    4. Recheck your wire (cap to plug)
  4. Krazy Comet
    Dismal Swamp
    Then it probably is.
    Rotate to TDC, mark dist position. Pull dist and rotate engine one turn back to TDC, reinstall dist...
  5. bmcdaniel
    If it backfires through the carb the plug is firing while the intake valve is open instead of after it closes and the cylinder builds compression. Way too much ignition timing advance.
  6. bmcdaniel
    Any chance the outer ring has slipped on the crank damper?
    71gold likes this.
  7. Izyk
    Izyk Member
    Ohio
    1970 Ford Maverick
    ok so I did this and got the engine to actually start but I have to advance the distributor as far as it will go and when it does run it smokes like a freight train and smells extremely burnt.
    distributor is pointing to the #1 spark plug
    (I’m guessing I’m a tooth off maybe?)
  8. Krazy Comet
    Dismal Swamp
    Probably..
    Move dist one tooth opposite of rotation...
  9. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Rotate the motor till #1 cylinder is moving up on the compression stroke, Rotate the crank by hand (with a socket and ratchet) until the timing pointer is around 15 deg BTDC on the harmonic balancer, Rotate the distributer body until the rotor aligns with the #1 spark plug mark. If it wont align up pull the distributor and rotate a tooth. This should get you close enough for it to start. The smoking is probably from all the cranking with out starting. it should clear out quickly.
    mojo and CA189HJN like this.
  10. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    What the others said. You're off a tooth on the distributor but you're really close.
  11. Mustang1989
    Mustang1989 Member
    Corpus Christi, Tx
    1994 Chevrolet 383 Silverado
    Man I really hope you're getting this worked out. Some really good suggestions/ advice in here.
  12. stumanchu
    stumanchu Stuart
    Portland, OR
    The original cause for the stall/no start may still be lurking. If your plug wires are old, you might replace them, or at least make sure they are not touching each other or something metal. If your battery ground cable is getting cruddy inside, I have seen them do stupid stuff. I sincerely hope you get it sorted out though.
    CA189HJN likes this.
