Engine light coming on
Discussion in 'Technical' started by bradmaniac, Feb 11, 2011.
  1. bradmaniac
    bradmaniac Member
    New York State
    1976 Mercury Comet
    Okay, I see a couple of replies got it confused so I'll clear it up....
    My Engine light is coming on when I am almost stopped. When I take off it goes out.
    The noises are only occurring when it's really cold and they don't last very long. I've driven allot of cars that make weird noises in really cold temperatures on startup, so those noises I'm not really worried about.
    Anyway, tomorrow I'll change the oil and see what happens.
    Thanks for all the really quick replies. You're a knowledgeable bunch for sure.
    :Handshake
  2. Craig Selvey
    I vote for too low of an idle as well.
  3. 71gold
    what...engine light...oil...alt...:huh:
  4. Walter Ehrat
    Walter Ehrat Member
    Iceland
    Ford Maverick Grabber ´73
    This is a typical "check engine light" in computer controlled engines. Has your car been modified with a modern EFI engine?
    *edit* sorry, you mentioned the carburator was rebuilt so no EFI!
    You probably are talking about the "Oil" or "Alt" light? If it´s the oil light then check the oil level immediately and have the engine oil changed.
  5. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    there is a "Engine" light in 75 and up mavericks. It comes on when the oil pressure is below 7psi or the coolant temp is above 250.
  6. Walter Ehrat
    Walter Ehrat Member
    Iceland
    aha :tiphat: cool. I guess the Mavericks were ahead of their time with "master" warning light for various systems :thumbs2:
  7. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    So, what's the verdict? did oil change help your situation? Did you check coolant level? are you still having issues?
  8. Jamie Miles
    Alto, GA
    I've had a few
    Yep. :yup:
