Engine Mount, Engine mount to Risers, and Risers to frame bolts
Discussion in 'General Maverick/Comet' started by Cruzin Illusion, Feb 28, 2015.
  1. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Does anyone know where to find new bolts for the engine mounts to block, engine mounts to risers, and the risers to the frame?
    Thanks!
  2. yellow75
    Tillamook Oregon
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Bolts, Yes. .......
    AMK sells the "riser to frame" bolts. Ford Part # is 56349-S, AMK # is B-12112.
    AMK sells the "mount to riser" bolts. Ford Part # is 56354-S, AMK # is B-10093.
  4. layne
    layne Member
    Orlando, Florida
    70 Maverick, 70 Mach 1, 70 Cougar Eliminator
    I went to the hardware store and got grade 8 bolts, nuts and washers for about a third of the price.
  5. junrai
    junrai Member
    rancho cordova ca
    any time I need bolts I hit home depot or lowes if it has to be heavy duty I buy grade 8 bolts
  6. yellow75
    Tillamook Oregon
    The bolts from a hardware store are good to use but I bet for Cruizins build he wont use nothing but what is suppose to be in it from the factory.
    The problem I have found is getting stuff from AMK it seems to that they had a minimum order or something like that when I was trying to get some of the bolts for the under engine cross member
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Tractor Supply sells 'em by the pound.
  8. 71gold
    like the hood hinges, fender bolts, gas tank, dash.....................:slap:
