Engine
Discussion in 'Technical' started by FrankieComet1960, Oct 17, 2021.
Tags:
  1. FrankieComet1960
    FrankieComet1960 Member
    Texas
    1960 Mercury Comet
    Hello I have a ticking sound in my engine can’t describe it. I talked with a friend he thinks it maybe my lifters but the noise is coming from under oil pan area? Any clues wud be appreciated
    Thanx
    I attempted to add short video but it wud not allow the file!
    Frankie
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Upload the video to youtube and share the link. There is a possibility it's an exhaust leak, that could sound like it's low on the engine and can mimic the sound of a lifter. When my header gaskets were starting to fail that was always my first though, time to adjust the valves.
    FrankieComet1960 and Maverocket like this.
  3. Craig Selvey
    My bet is an exhaust leak.
    rickyracer and FrankieComet1960 like this.
  4. FrankieComet1960
    Texas
    1960 Mercury Comet
    Thanx R Miller that cud be a source Because I can see they my Manifold is not sitting as securely as it shud be!!
    I’ll try that route before I take down the bottom Pan!!
    Frankie
    RMiller likes this.
  5. FrankieComet1960
    Texas
    1960 Mercury Comet
    Craig
    Thanx!
  6. FrankieComet1960
    Texas
    1960 Mercury Comet
  7. FrankieComet1960
    Texas
    1960 Mercury Comet
  8. RMiller
    Kennewick, WA
    That doesn't sound like exhaust, it does sound like valve train but I'm also listening to it on an old android phone so I could be wrong.
  9. 71gold
    check oil level.
    when was the last oil change?
    FrankieComet1960 likes this.
  10. rthomas771
    You engine has a mechanical lift cam. valves need to be adjusted ever so often.
  11. Krazy Comet
    Dismal Swamp
    Agreed...
    Changing oil may improve oil pressure, but isn't going to help out of adj rocker arms.
  12. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    It definitely sounds like lifters. First, I would check your valves with a feeler and adjust accordingly. Might correct the issue. If not, they are available to replace and not expensive. You will need a lifter removal tool, however, as they sit way down in the head in this I6 engine unlike an overhead cam engine. Tool isn't expensive either.
  13. FrankieComet1960
    Texas
    1960 Mercury Comet
    Hello 71fold I have only driven it about 200 miles since the last oil change?? It’s been down for some interior repairs?? Thanx
  14. FrankieComet1960
    Texas
    1960 Mercury Comet
    Thanx Constable! I’ll try to see if I can make that happen does the engine need to be pulled?? Those tools I don’t have!!
  15. FrankieComet1960
    Texas
    1960 Mercury Comet
    Thanx Rthomas
    I also spoke with Randy and I’m placing an order for those retainers!!
    Thanx!!
    rthomas771 likes this.
