Engine
Discussion in 'Technical' started by FrankieComet1960, Oct 17, 2021.
Tags:
  1. Krazy Comet
    Dismal Swamp
    To adj valves, remove valve cover, simple operation. I'll see if I can find the procedure in Ford shop manual.
    Should be half a billion youtube videos on valve adj....
  2. FrankieComet1960
    FrankieComet1960 Member
    Texas
    1960 Mercury Comet
    Thanx Krazy Comet!! I’ll look again didn’t see for my specific Vehicle but that’s a Good starting place I agree!!!
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I'm so used to discussions on 69 and newer engines it never registered this was old enough for solid lifters.
    FrankieComet1960 and Krazy Comet like this.
  4. Krazy Comet
    Dismal Swamp
    I think they switched when the 200 was introduced.
    RMiller likes this.
  5. 71gold
    how many miles on the car/engine?
  6. FrankieComet1960
    Texas
    1960 Mercury Comet
    71 it has 68,000 miles
  7. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    No it doesn't. Like I said, you will need to buy or borrow the valve removal tool.
  8. Krazy Comet
    Dismal Swamp
    Valve removal tool?
    All we're talking about is adj rockers, on 6 cyl can be performed with a common boxed end wrench.
    71gold likes this.
  9. Krazy Comet
    Dismal Swamp
    This is Motors procedure is only one I'm able to scan(lower left corner). One in Ford shop manual is on inside of page so doesn't lay flat on scanner. Clearance is listed at .016 hot, .018 cold would be fine.
    If you are planning on keeping a old car around, the Ford shop, Motors or Chilton are worth their weight in gold.
  10. Constable
    Portersville, PA
    I was referring to replacing the lifters. That's what you need the tool for.
