Exaust manifold bolts rusted and rounded
Discussion in 'Technical' started by Halebopp, Apr 22, 2008.
  1. Wantamav
    Wantamav Located in Macomb Mi.
    Michigan
    '71 2 door
    I rescently started down the same path with my '71. Manifold was leaking at the head & I couldn't stand the old farm truck sound that resulted. I used ford brand rust penatrant (the best made in my experience) and soaked 'em good for a couple days in a row. I managed to get every bolt out except one! :mad: My best option was a metric 6pt impact socket (fit very tightly) and a gentle hand on a really long breaker bar. I would not waste my time heating unless you have oxy/acy setup as most of the bolts thread into a meaty part of the head. Once I'd broken the head off of the frozen bolt, the manifold fell out of the way. I tried to reweld the head of the bolt back on the stub three times & broke it off three more times. Each time i broke the bolt off it was that much closer to the head. Eventually it was time to take the head off and drill / helicoil. :( Once I had the head off I realized how much attention the valve train needed... What started out as a quick e manifold gasket replacement has turned into:
    Valve job (new valves, ground seats, new guides, retainers & seals)
    Resurface Head
    Resurface e manifold. gasket had blown due to a rusty pitted surface.
    New gaskets
    Repaint valve cover...
    & Countless new fasteners
    Should be back to healthy this weekend.
    Moral of the story, be very careful with e manifold bolts! :oops:
  2. Halebopp
    Halebopp Member
    Ankeny Iowa
    Yeah all that heating cooling rusting etc has to make them very brittle it seems.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Oh,, and proper amounts of cussing are advised.:yup:
    Dan
  4. Bob Wiken
    Fayetteville, Arkansas
    I must have been very lucky. When I topook mine apart, all the bolts just came out with no problems at all. Good luck to you
