exhaust and jetting question
Discussion in 'Technical' started by borjawil, Sep 27, 2011.
  1. baddad457
    Because that's what you'll get with either of those two muffler choices: more noise and more headaches if you drive it enough. A single straight 3-3.5 inch pipe will sound better than those two mufflers, run out the sides ahead of the rear wheels.
  2. borjawil
    borjawil Member
    lansing mi
    1972 Ford Maverick Sprint
    i see. any issues with the way it will run with just the x pipe then larger 3'' -3.5'' with no mufflers?
  3. Craig Selvey
    As also stated....it is just plain noisy. You will have a "drone" type noise. I have had 6 cyls with glass packs, turbo mufflers, no muffler at all, etc. Kind of a novelty at first....but after awhile too much darn noise. Eventually I switched to a standard, quite muffler and was much happier.
    I think you will also want an over the axle pipe. That will cut down on the noise as well.
  4. Mad_Cow
    Mad_Cow Member
    South Dakota
    "Madison"-1972 Maverick
    true. the sixes have a screach about them.. I drove mine a year and loved it... again personal pref.
  5. baddad457
    I'd try it then decide what you like. Glasspacks and Cherrybombs have never been known to be a pleasant sounding muffler. And they've been around for 50 years now. And the sound gets worse as they age. Now glasspacks ? the longer they are, the quieter they are, but as I said above, the sound changes as they age.
  6. borjawil
    borjawil Member
    lansing mi
    well ill start with the x pipe on to larger 3'' pipes and see if I like it. figured I'd start cheap and not waste money on something I might not like. thanks for the help guys!
  7. baddad457
    If you're going to do duals, then do it with dual 2 to 2.5" pipe along with the X
  8. borjawil
    borjawil Member
    lansing mi
    gotcha ok. my other question is do I have to have a certain or ballpark length of pipe before the "X" and after it or does it not make a lot of difference?
  9. baddad457
    That's a 64 million dollar question. Put it where it fits, as close to the collectors as you can, only running it on a dyno and changing locations would you actually find where one location would be better than another.
  10. borjawil
    borjawil Member
    lansing mi
    mmk, the header i am getting dont have collectors but i can get it pretty damn close to the point where all the pipes meet. cant wait til they get here. taking forever.
