Exhaust Leak
Discussion in 'Technical' started by Krax, Jul 5, 2010.
  1. blugene
    I would say the satisfaction in this case is getting it fixed. I agree that DIY is satisfying but this kind of repair can be fustrating UNLESS the bolts come right off. Not everyone has a torch or studds if they break or are damaged. THEN hopefuly the parts guy sold you the correct gaskett.
  2. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    Yeah I don't have a torch, I used brute strength to get the closest one off, but the one closer to the windshield refuses.
  3. blugene
    Hmmm.. if your half way there then soak it and try again. If it breaks at least you have the one you can put back and get it to the shop...I guess.
  4. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    did you use some kind of pen oil?
  5. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    Idk what Pen oil is, but I just used a crescent and got one halfway before I died of exhaustion, the other won't even break at all. I'm going to get some nut-breaker stuff that you spray on nuts I don't remember what it's called from my girlfriends mom maybe that will work... I sure hope so, and now I'm struck with my reverse lights not working and I don't have a fuse tester, so that's great.
  6. Dave B
    WD40, spray the studs and let them soak.
    One thing I learned when I was young, and started working on cars was, I hate exhaust, whatever its costs, take it to a shop, then it'll be done.
    As for the reverse lights, have you been playing with the radio wiring?
  7. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    SLOW DOWN! TAKE YOUR TIME! PEN=PENETRATING OIL. let it soak a good half hour, it will give. my wife pulled hers, you can do yours. now- one turd at a time, get a 12 volt tester and see if your getting power back to the lights. it may be a ground. these cars are well known for it. there is a thread about this . do a search,most of all dont get wound up. slow down. it will all work out. we will help you.:Handshake
  8. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    Yes I have played with the radio wiring a little, I haven't disconnected anything I never had a stock radio, had a cd player in there at one time but gave it to somebody. How much do the testers usually cost? I'm only 19 I don't really have a clue what I'm doing, so I need to get some penetrating oil now and a tester. I swear it's one thing after another. :(
  9. blugene
    I bought a tester at Wal Mart for $3 if I remember right. It was a 6 and 12 volt tester. I once made one using the interior light lol.
  10. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    you can pick one up at autozone for about $5.00 same place you get pen oil. do you have access to tools? compresser, as if your going to be doing this as diy, you can get by, but your going to need some basic's. is there a harborfrieght in stevenville. i worked at chapporal steel when i was 16.
  11. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    I don't think so, or atleast I've never noticed one and I've lived here all my life. And I found a tester made from an interior light in my trunk but it doesn't work, probably too rusty it has been there since I got the car. Yes I have tools, but not a compressor or anything fancy just basic tools.
  12. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    well you have a good foundation to start with. im sure there is some kind of auto parts store(checker,oriely,kraggen,pep boys, billy bobs) what ever, be cool to them they will get to know you and can be very helpful and if any have a frequent flyer card, take advantage. save money where you can.
  13. Dave B
    If anyone has hacked into the factory wiring, the reverse lights are fed off the radio light circuit.
  14. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    Well it looks like the previous owner did some modifications of his own, idk what but there's electrical tape everywhere and if so idk what i'm going to do. I don't know much about electrical work.
  15. don graham
    I just needed to break some nuts loose on my Mustang GT. I used PB Blaster. Let it soak for a few hours and then they came off. :)
