Exhaust manifold
Discussion in 'Technical' started by warboy, Jan 23, 2017.
  1. warboy
    warboy Member
    pennsylvania
    1972 ford maverick grabber, 1977 ford maverick 4dr 351 v8
    So my exhaust manifold for my 351w is touching my shock tower on the passenger side, is it OK to run it like that or should I pull the engine and make more room (engine is all bolted in and mostly wired up)
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It should not be touching. The engine moves when it's running. Are you using Maverick-specific exhaust manifolds?
  3. warboy
    warboy Member
    pennsylvania
    No idea what manifolds they are but would it be bad to leave it that way
  4. warboy
    warboy Member
    pennsylvania
    Only touching a tiny bit
  5. Krazy Comet
    Dismal Swamp
    It'll wear it's own clearance...
    The engine tends to "lean" to right under load, note the area touching will get very hot...
  6. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Not to mention transfer of vibration into the body from the motor. - Matt
    Hotrock likes this.
  7. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Larry, are there Maverick specific exhaust manifolds for the 351W? Or, are you talking about using Maverick 302 manifolds?
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The Maverick exhaust manifolds for the 302 also fit the 351W. Of course they don't flow as well as headers, but at least they fit the car.
  9. Krazy Comet
    Dismal Swamp
    The 351 was never offered in a Maverick, so there are no manifolds for such application... AFAIK excepting possibly for exhaust angle, all factory manifolds are approx same...
  10. mcknight77
    mcknight77 Member
    Boise, ID
    302 manifolds are probably what I am going to use initially.
