Exhaust Question
Discussion in 'General Maverick/Comet' started by Tannersg1, Sep 7, 2014.
  1. Tannersg1
    Tannersg1 Member
    Classified
    Assuming air/fuel ratio is set properly what is the best way to lessen the exhaust/fuel smell that a long tubed header 302 emits? I have 6901's with thrush mufflers and a full dual exhaust but the fumes are obnoxious! Would high flow cats, h-pipe or x-pipe help? Thanks!
  2. Drew Hierwarter
    Drew Hierwarter Member
    Kingsport, TN
    1976 Comet
    Are sure that air/fuel is correct? You shouldn't be smelling anything if it is. Pull the plugs and see what they look like. Are they black, do they smell like gas, are they wet? Usually if you're smelling fuel in the exhaust the engine is running way too rich.
  3. rthomas771
    Do you have the hood to cowl seal? If not, you will smell gas. The seal will keep fumes from getting sucked into the cowl's fresh air vent and exiting through the interior's vent
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Your problem has nothing to do with the headers, unless there's an exhaust leak.
  5. 71gold
    you say..."full dual exhaust"...where does it exit?
  6. Tannersg1
    Tannersg1 Member
    Classified
    Rear of the car!
  7. Tannersg1
    Tannersg1 Member
    Classified
    Thanks for the reply. Pulled a couple of plugs and so far they look good! I'll pull the rest of them tomorrow to see what's going on with them.
