Exhaust Systems for Mavs?
Discussion in 'Technical' started by tbirdz12, Jun 25, 2006.
  1. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    Thanks fan2488, I have a garage now and 2 welders. Now I am going to have to get to welding on some pipes and maybe shock towers.
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i have the passenger side done and installed all the way out the back. was not as bad as i thought. mainly just had to section the pieces to form different angles. then cut to length. have the drivers side done up to the rear end. this tail pipe might be a bit of a challenge. but i think i can do it. here is some pictures of the pipe right after the header before and after. the green tape is the amount that had to be removed. then rewelded and ground down.the middle pipe had no mods done to it, just shortened two inches. so if you wanted to stop at the rear axle this is a real easy mod. will take more pictures when done. the left over pieces can be used for a h-pipe if you like.
  3. fan2488
    fan2488 Member
    spring,TX
    here is a few more pictures. this is what i had to do to the drivers side tailpipe to clear everything ( i hope).
  4. fan2488
    fan2488 Member
    spring,TX
    this is the final product on the passenger side. this tailpipe did not require as much modifying. it will look the same on the other side
  5. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I see a heat bend:yikes: :D rookie:p
    or maybe just where you welded a hanger or something.
    J/K
    Looks very nice. (y)
  6. fan2488
    fan2488 Member
    spring,TX
    its a hanger. all rebends were made by taking a slice out of the pipe and then welding.but you are right i am a rookie,its my first exhaust.
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Is that tire defective?
    Or is your right foot just heavier than the tire? ;)
  8. fan2488
    fan2488 Member
    spring,TX
    not sure if the car can even spin the tires.those are the old tires on the car. new ones not mounted yet. this total exhaust cost a little over $300.00 this includes the headers. the muffler shop where i was going to take it, was going to charge $1500.00. that was from the manifolds back with 2" mandrel bent pipe.
  9. Mavaholic
    WOW!!!!! $1500!!!!!! I can see why you went that route. Is it mandrel bending that drives up the cost?
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Man, I guess I forgot how much they were going to charge you for the exhaust system. I figured it'd be closer to $400 or so.
    I guess I should stop "figuring".
    Good luck on the driver side. You're almost home!
  11. Mavaholic
    My dual exhaust was only $350 but they are not mandrel bends. I had the headers, mufflers, and X pipe in hand. They rest they made.
  12. fan2488
    fan2488 Member
    spring,TX
    regular 2" exhaust was going to cost $400.00.thats from the exhaust manifolds back.since one of the manifolds was broke. thats why i went ahead and went this route a little over $300.00 for headers and 2 1/2" mandrel bent exhaust is alot better in my book. i did have to buy a small 45 degree bend today for $20.00,but that should finish it.
  13. fan2488
    fan2488 Member
    spring,TX
    finished the exhaust.here is a look from the back. will post some of the drivers side tailpipe from under the car, when i resize them.
  14. fan2488
    fan2488 Member
    spring,TX
    here is the last of the pictures. not to hard if you take your time.
  15. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    What year mustang tank should you use.
