Exhuast bolts... help!
Discussion in 'Technical' started by 14yearold, Apr 18, 2015.
  1. 14yearold
    14yearold Banned
    Virginia
    During the replacement of my exhuast manifold gasket, almost all of my bolts either stripped or broke of in the head. I have taken the head off and had a machine shop take the bolts out and completly refinish the head and valves. I have every thing back together except the manifold, anyone know where i can order some manifold bolts for a 200 slant 6? I dont know where to order these or what size they are because the machine shop didnt give them back including my thermostat housing and spark plugs.... any help i am grateful for.
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  3. 14yearold
    14yearold Banned
    Virginia
    Thanks!!!!!! :cheers::cheers::cheers:
  4. Acornridgeman
    Wisconsin
    Are all the threads good? You might want to look into that before ordering bolts. You might need a slightly longer than stock to get onto decent thread or possibly even a different size bolt if they were worked on by the shop.
  5. 14yearold
    14yearold Banned
    Virginia
    some where fine and he helicoiled the ones that werent
  6. Acornridgeman
    Wisconsin
    Sounds good ...................... :)
    14yearold likes this.
  7. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    I would use studs & put nuts w/ lock washers on,& use stainless steel ones,Then if you ever have to do it again,which you might because those heads are bad about cracking,it will be easier to get the manifold off.
    FomocoBoy and Maverocket like this.
  8. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Good advice.
  9. FomocoBoy
    FomocoBoy Member
    Western Canada
    1969.5 Maverick
    I was scrolling down to write the same thing. Think I would go with some anti seize on the studs too...
