explorer head ?
Discussion in 'Technical' started by newtoford, Apr 2, 2008.
  1. Halebopp
    Halebopp Member
    Ankeny Iowa
    THis says non ps we don't want someone is confused ??? :hmmm:
  2. Halebopp
    Halebopp Member
    Ankeny Iowa
    Hey Scooper that was you , there must have been a typo, the non p's don't obstruct ?
  3. scooper77515
    DOH!!! :slap::slap::slap:
    That was my mistake...I of course meant that the Ps are not desired...
    I will go back to that post and fix it now...
  4. chupafuego
    chupafuego PhxCOMET
    Phoenix
    1971 comet
    The p stands for pain in the Rear. The plugs are angled for detonation but WILL HIT MOST HEADERS> I made it work but WOULD NOT DOO IT AGAIN. $500 in 67 stand nickle tri ys drop bracket and a hammer . If you look at a stock p manifold it looks like a pile of noodles. Spend the money on the non p heads.
  5. scooper77515
    Mine worked, but I ended up using a second flange from a set of scrapped headers. Ground off all the header material leaving just the flat part. Gasket on both sides of it, then the 6901s. This gave me about 1/2" extra clearance.
    I also had to use Accel Shorty spark plugs at $13 EACH! Only ones I could find that fit that head. Then 90* hei boots on the plug end.
    All in all, ran really good, you just had to unmount the motor, lift it off the mounts and remove the driver side header, remove all the spacers and gaskets, etc, before you could even swap a plug or remove a plug wire.
    WAY too much work for spark plugs.
    With the NON-P heads, the plugs actually seem easier to get to then they were on the stock heads...:huh:
  6. Halebopp
    Halebopp Member
    Ankeny Iowa
    Thanks for clarifying, this is good info as I make decisions on my v-8 swap
  7. chirt
    chirt Carlos Hirt
    Massachusetts
    So do you still have the gt 40p in your car? cause i have them on mine with heddman hedders and i only used 90 degrees boots and bent the hedders a little but after running the engine in high rpms the boots fried:cry:
    So what should i do? what about the mav's original manifolds will they fit these heads in the mav?
  8. scooper77515
    Shorty plugs. Accel P526S, $16 each.
    That will give you another 3/8" clearance.
    Then I used a flange from an old header with the tubes cut out, and a gasket on each side, giving me another 3/8" or so. Almost an extra inch total, but still had to remove the header and jack up the engine to get to the plugs and boots.
    I swapped over to the NON-P GT40 heads for this reason.
  9. chirt
    chirt Carlos Hirt
    Massachusetts
    Thank you scooper!
  10. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Do you think this would solve the problem?
  11. scooper77515
    Might not be enough room between the plugs and header tubes for it...:huh:
  12. chirt
    chirt Carlos Hirt
    Massachusetts
    I just orded 5 of them today!:thumbs2: i hope it will work plus with the shorty plugs and another flange like scooper did.
