Factory compressor numbers
Discussion in 'Technical' started by Mavdad77, Sep 8, 2021.
  1. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    Well...I guess the time has come for all good OE parts to fail. 1977 Maverick with 250I6 and auto transmission. Recently had the A/C serviced and the next day she overheated. Only does it when it has been under A/C load for 30 minutes or more. Trying to verify that the number on the tag is the part number I should be cross referencing.
    The number is:
    YP 04636 7
    D50H 2875 A2B
    09-76
    Any help would be greatly appreciated.
    Mark
  2. Krazy Comet
    Dismal Swamp
    What are you looking for??
    Likely radiator is partially clogged or has a fan/shroud issue...
  3. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    I am trying to figure out which of the numbers from the first two lines of the compressor tag is the OE part number. Yes, I am going to do a diagnostic on the whole system however, I have that sinking feeling that a new compressor and clutch is in the near future. Rock Auto has four different compressors and I want to make sure I buy the right one if it comes to that.
  4. Krazy Comet
    Dismal Swamp
    The A/C compressor is likely the least of your worries. If it's binding enough to cause overheating engine, performance would suffer dramatically.
    The basic part number for compressor is not 2875, that's apparently a bearing in the clutch assembly. Compressor number is 19703. Master Parts lists only one replacement, D2AZ-19703-B. Likely were different compressors used, apparently the D2 replaced all.
    Hotrock and BBMS18 like this.
  5. 71gold
    when you said ..." had the A/C serviced '"... did they flush the complete system?
    remove the A/C belt and see if anything changes.
  6. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    71 gold, the a/c was evacuated and then recharged and checked for leaks. Today I flushed the entire cooling system and am more than a little confused. The specs I looked at says it should have 9.7 quarts of coolant. When I drained it I got 6 quarts. I filled it with distilled water, only held 4 quarts. I started the engine and ran the heater on high to get distilled water in the heater core, after 20 minute I shut it off and drained the system. 5 quarts came out this time. Next I put radiator cleaner/flush and another gallon of distilled water, it wouldn't hold any more. Ran it at highway speed for 15 minutes with the heater on high again and then ran it for another 15 minutes with the a/c on high. Got it back home, shut everything down and it overheated. Also, when running the a/c it blows cold out of the dash vent but as soon as I accelerate it switches to the floor vents, let off of the accelerator and it blows out of the dash vents.
    Thoughts?
    Oh yeah, heater core not leaking, nothing from the water pump weep hole, hoses aren't collapsing. Factory fan is NOT a clutch fan.
  7. mojo
    Do you have a fan shroud? How many blades on the fan? Is it pucking when you shut down?
  8. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    Yes I have a fan shroud and the fan has 5 blades.
  9. Krazy Comet
    Dismal Swamp
    Problem with the vacuum reserve tank or lines, common issue...
    You are saying it boils over when cut off?? It's common for temp to rise during heat soak. Sounds like weak radiator cap.
  10. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    can you please tell me where the vacuum reserve tank is on a 250 straight six? Or maybe post a picture?
    Thanks
  11. dyent
    dyent Member
    vancouver bc
    Vacuum reserve tank (looks like soup can, black) was located below the blue charcoal tank on passenger side just in front of firewall........
    David
  12. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    You wouldn't happen to have a part number for a replacement would you?
  13. Krazy Comet
    Dismal Swamp
    Not everything needs to have a new part thrown at it. Previous owner of my Fairlane fell victim to that procedure. After a new carb and spark plug wires, both with issues were installed, he was lost.
    Remove tank and vacuum test, often one way valve(s) or leaking vacuum lines are at fault.
    BBMS18 likes this.
  14. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    It looks like I have a vacuum reserve canister about the size of a baseball and then I am not sure what is mounted above it. 0AB13C08-5486-4070-99A5-E24A98B2EC32.jpeg ACDE84BA-6AF2-4F95-8B13-0A1FFE19ABE1.jpeg
  15. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    That piece above it is the same as the blue charcoal canister in David's picture. I am not sure if either of those parts in your picture are actual Maverick/Comet parts. Someone else may be able to confirm.
