Factory compressor numbers
Discussion in 'Technical' started by Mavdad77, Sep 8, 2021.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    That sure looks like an overflow tank of some kind, never seen one.
  2. Krazy Comet
    The round blue & cream color rectangular containers are charcoal canisters, fuel tank vents into these, have zero to do with A/C function.
    The round, black "can" under blue tank is the A/C vacuum reserve.
    CA189HJN likes this.
  3. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    Thanks KC! I am assuming that there is a missing cap on the left side as you look at it?
  4. dyent
    dyent Member
    vancouver bc
    There is a flexible hose that attaches to fitting and goes to side of air cleaner housing........
    David
  5. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    Thanks David
  6. dyent
    dyent Member
    vancouver bc
    Do you still have the original air cleaner assembly?
    David
  7. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    Yes sir
  8. dyent
    dyent Member
    vancouver bc
    If your air cleaner assembly still has the fitting for attaching the flexible hose to fitting on charcoal filter unit, you can probably use any tubing (rubber or vinyl) so long as ID is correct, it is not under any pressure, so should be fine. Picture is from my 302 air cleaner, but you can see the black fitting where the flexible hose attaches........
    David
  9. Craig Selvey
    The AC should switch to coming out the DEFROST when accelerating. Very common and NOT an issue. Just the way it is. All my Maverick AC cars do this.
  10. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    I would like to thank everyone for their input. I flushed the radiator three times, last time I left the cleaner and distilled water in for a week and drove it back and forth to work every day. Heater on in the morning (with windows down) :) and A/C on in the afternoon. After 5 days I drained it refilled with antifreeze and have not had any issues.
  11. Krazy Comet
    Glad to hear...
    I doubt they were that way from new(time to break out the shop manual), I don't remember my '75 Granada having that issue.
    Easy enough to install a one way vacuum valve, if it still switches, there's a leak(yeah, probably in selector).
  12. Mavdad77
    Mavdad77 Member
    Texas
    1977 Ford Maverick
    Does anyone happen to have a PDF of the FSM/TSM for the 77 Maverick the could e-mail me?
  13. Drifter69
    Drifter69 Member
    Maine
    '72 Maverick Grabber
    It may be very common, but it should NOT happen. This indicates a manifold vacuum loss under load, which in itself is normal, but the system was designed to utilize a vacuum reserve to hold constant vacuum to accessories when under load. Its a simple system, but requires functioning one-way check valves, a reservoir that doesn't leak, and vacuum hoses and pots that also don't leak. If any one (or more) of those parts is not 100% vacuum tight, the vent switching symptoms will happen.
    mojo likes this.
  14. Craig Selvey
    I am speaking about heavy, extended acceleration. Eventually....those little "cans" run out of vacuum. :D
  15. Drifter69
    Drifter69 Member
    Maine
    The OP stated "Also, when running the a/c... as soon as I accelerate it switches to the floor vents, let off of the accelerator and it blows out of the dash vents."
    "As soon as" = not normal.
    Should be fixed for proper function as-designed. The system was not designed to behave this way, nor should it.
