Factory Five modernizes the '33 Coupe
Discussion in 'Ford Industry News' started by Mav.bot, Sep 12, 2008.
  1. Mav.bot
    Mav.bot Member
    Filed under: Time Warp, Coupes, Plants/Manufacturing, Ford, Special/Limited Editions
    Click above for more shots of the '33 Hot Rod from Factory Five Racing
    Factory Five currently sells the most popular Shelby Cobra kit by far. One of the reasons that more people build the FFR Cobra than all other Shelby kits combined is that it's the easiest one to finish, as it comes with everything needed minus a donor Mustang. That same philosophy is behind the new '33 Hot Rod kit from FFR. Any small block Ford V8 engine will fit, along with the buyers choice of transmission and a Ford rear end. The benefits to starting with a completely new foundation rather than an existing Ford product from the '30s are apparent when you take a look at that triangulated tube chassis and its in-board coil-over front suspension. Plus, with just 2110 pounds. to push around with its fiberglass body, this is one '33 that will have no problem getting out of its own way.
    Want one? The kits are currently priced at just under $20K and are shipping now. A short wait 'till December will ensure that no parts are on back-order. That should give you plenty of time to source an appropriate engine, transmission and rear axle and rolling stock. Now, all you need to do is pick a color.
    Gallery: Factory Five '33 Hot Rod
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    [Source: Factory Five Racing via NextAutos]
    Read | Permalink | Email this | Comments
    More...
