Factory Floor Shift Automatic Bezel Screws
Discussion in 'Cosmetic' started by Craig Selvey, May 2, 2006.
  1. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    Dan sometimes brake fluid will cause rubber to swell up and distort and you don't want brake fluid to get on any painted surface as it will eat the paint. maybe put a small amount of white lube on the seal or silicone...jm .02$
  2. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    This thread made me have a look at the screws and they were old and ugly, so mine are now stainless too :29:
    Looks great thanks :drink:
  3. Craig Selvey
    I decided to restore my old floor shift bezel. It polished up real nice...and I repainted the black. I also decided to paint the screw heads black. This picture didn't come out very well.....but it looks pretty darn good and the screw heads just make themselves invisible inside the black paint.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Looking good ... lets see how long your seal lasts ...
  5. Craig Selvey
    I can tell already that it isn't going to last long. It is to darn thick.
  6. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    Craig,
    It looks very nice, I don't think you need a new one. Hey, just briefly, is it horribly difficult to convert an automatic on the column to a floor shift style like yours?
    Art
  7. sierra grabber
    sierra grabber Certifiable
    northern nevada
    difficult is a relative term. some people can weld in whole panels and make it look like factory and think its easy:bowdown: . the stock style floor shifter can be put in without much modding other than cutting the hole for the bottom half to bolt into. the top half rides in that "bucket". if you want to eliminate the shifter assembly off of the column completely, you have to replace the column. but if your good at metal work, you can probably pull the shifter collar off and remove the wheel lock mechanism to make it look stock. if i remember right you may have to change how the shifter on the transmission points to another direction to work with a floor shifter linnkage. if you go aftermarket or with aftermarket parts it may vary some of these mods. good luck(y)
  8. Craig Selvey
    My car was already a factory floor shift.
    Sierra covered it pretty well.
  9. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    I have not taken my floor shifter apart to get to that seal yet...it
    needs replaced also....could another rubber be fabbed to take it's
    place like a bike inner tube maybe? Not sure how that is held in?
    Don
  10. Craig Selvey
    The rubber has to be rigid in order to stay up in a "hoop" type pattern. Origianlly this was done with metal inside the rubber. On the repops....they just use a thicker rubber.
  11. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    Well, getting the bezel screws out was a real pain. 2 were missing and the other 2 were fused to the aluminum housing. Both of those broke off and once I had
    the bezel off I noticed the other 2 had broken off too....:cry: Looks like I will
    have to try and drill them out or look for another shifter. This one has the
    black bezel anyway...not chrome. And the rubber seal was shot...
  12. mav man
    mav man Member
    wi
    70mav
    does anyone know what year mustang shifter bezal and seal works on the mav auto floor shifter is it the 67-68 or 69-73?
  13. rayzorsharp
    It would be the 69-73 style. The 67-68 is smaller.
  14. dmhines
    Cumming, GA
    Yup .. Ray is correct .... the picture of the one in my car is a Repopped Bezel listed for a 69-73 Mustang ...
  15. dmhines
    Cumming, GA
    Craig ... the only picture I could find of the shifter is on the back of the 1971 Sales Brochure ... it does show it with black screw heads ....
