Fan hits radiator!!!!
Discussion in 'General Maverick/Comet' started by fuelish351, Apr 6, 2015.
  1. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    I recently bought a 73 mav 6cyl, I noticed when I bought it the rad cap hit the hood, so today I lowered the rad to the right mounting holes. Went to start it and come to find out fan was hitting the upper hose, so I raised it back up and found a temp hose at the shop now if I shut the hood all the way it hits so I drove home with the hood unlatched:shocked:
    Is my engine to high, fan too big, wrong upper hose?
    pics are of the temp upper hose(looks just like the old one) with the radiator higher than it should be
  2. Krazy Comet
    The fan appears to be too large...
    Static likes this.
  3. D-Man
    D-Man Member
    Texas
    75 Comet
    I had the same problem with my radiator cap. My problem was the hood latch had come loose and the pushed the latch up and let the hood sit on the cap.
  4. fuelish351
    fuelish351 Member
    San Jose, CA
    how big across is the fan supposed to be?
  5. 71gold
    get the number off the fan and check it for the right one.
  6. CaptainComet
    I don't know what fan came on 6 cylinder Mavs, but my factory fan is a bit of flex fan. The blades can flatten a bit a speed. That stamped steel blade screams "truck" to me, but that just a guess.
  7. Craig Selvey
    6 cyl fans look like that one.
    Need more pix of the radiator. I would guess it is the wrong one...because the neck on the cap look s really tall...but hard to tell in that pix.
  8. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    My 73 w/ 250 had a flex fan when I got, and had a motorcraft part number. The radiator looks incorrect to me too though.
  9. Krazy Comet
    Yep std cooling fans look like that one, A/C & HD were generally flex or had 5 maybe 6 blades...
    If fan is more than approx 17½" its likely the incorrect one...
  10. rthomas771
  11. junrai
    junrai Member
    rancho cordova ca
    the radiator looks to be the wrong one with it slanting down at the neck and the fan looks like it has a HUGE blade on it. I dont remember the fan in my boys old comet with a 250 being that big/thick looking
  12. Acornridgeman
    Wisconsin
    The inlet looks to be bent down - that would make the fan hit the hose. There isn't much room there to begin with.
  13. rthomas771
    Here's my fan clearance on my 6 cyl
    71gold likes this.
  14. fuelish351
    fuelish351 Member
    San Jose, CA
    Well I went to the parts store and bought a 15" flex fan for now, the stock fan measured 17". Did you know flex fans are almost $60:yikes: The guy I got the car from said it was redone recently
    It looks like your radiator is a different syle than mine that might be the issue, thanks for the pic
  15. Acornridgeman
    Wisconsin
    Just measured up one from a 200 - Stock fan is 17 1/4"
    :cheers:
