Fender well headers?
Discussion in 'Technical' started by Mustang Mike, Apr 27, 2010.
  1. Mustang Mike
    Mustang Mike New Member
    Hi guys,
    I have some buddies that are in a bit of a predicament. I thought they were building a 302-based stroker for a 1973 Maverick (that used to be mine), but I've learned recently that they'd built a 351W for it!
    Now, of course, they're hit square upside the head with the headers issue.
    I've done a lot of research here, and I know about Crites. I know you can't find a set to easily install from anywhere else. I know about their 5000' pipe deal and won't build them, etc. I know about cutting shock towers and the MII swap. They're not really amused by any of this, understandably (although I am fairly amused at their motor choice without doing research first).
    So... they're now wondering if they could maybe do some fender wells. I haven't looked at the engine compartment of that Mav in a long time, so I don't know.
    Anyone here done that, or have any other recommendations?
    I'd like to help these guys out if I could.
    Thanks for your time.
    Mike
  2. maverick75
    these are the only ones i've ever seen.
    but this was a 460/MII build...these cars just dont have alot of room there, especially with the shock towers.
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    The shock towers are the problem on Mavericks. Mustangs had a wider engine bay so it is not as big a deal with headers on a 351W. Most folks notch the spring towers a bit, it gives some room. There are several threads on here describing what others have done, just use the search box to look at them....
