Figured out the brake issue... now what?
Discussion in 'Technical' started by TarHeelDevil, Aug 26, 2012.
  1. injectedmav
    injectedmav Member
    Georgia
    Fill it up at the P/S pump reservoir, start the engine and turn the wheel back and forth a couple of times, check the fluid and repeat until the pump whine subsides and you have full power assist, check the fluid level and top off or remove fluid as necessary(y)
  2. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    So I've successfully completed my first power steering line swap! Between changing brakes and swapping lines, I think I'm now experienced enough to swap and engine haha. Thanks for all your help folks!
  3. 71gold
    nothing but...nuts n bolts...take plenty of pics. and label the wires/vac. lines...:yup:
  4. Dave B
    Awesome!! Did you remove that hose clamp? There is usually a screw that holds the cover over the stud on, maybe it broke...or the clamp was just easier..
  5. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    At the very least rotate the clamp so the head of the screw can't make contact with the hose.
  6. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    I rotated the clamp, but kept it in place as it seemed important.
  7. Craig Selvey
    I have seen a hose clamp on virtually every Maverick I have ever owned. It is there to hold the metal supply lines in place against the center link.
  8. simple man
    simple man Member
    Bunnell,Florida
    Thanks Craig! I wondered what it was for. Mine has one too. :)
