Finally some front end pictures
Discussion in 'Technical' started by maverickdvm, Feb 16, 2007.
  1. Jamie Miles
    Alto, GA
    I've had a few
    That is awesome. :thumbs2:
  2. 1badmav
    1badmav Member
    I am How Much???
  3. okibono
    okibono Member
    cali
    call me...
    I sent you a pm....(y)
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Okay. I'm awake now. :slap: :whistle:
  5. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    It is a very cool set up! I have the Fat-Man kit, it is also a strut type front end, but I like you rk member much better. But mine should be a nice driver, not going for the racer.
  6. okibono
    okibono Member
    cali
    what is the motor mount setup in that thing? And if the kit uses SN95 Mustang parts, why is the strut/shock assembly Mav specific? Or is it the upper mount is Mav specific?
  7. maverickdvm
    maverickdvm Member
    Michigan
    From what I understand, the strut is the Maverick specific part that they built just for the Maverick. The SN95 stuff refers to the spindles. There is an adjustable caster a arm that I am in the process of finding out about as well. You can see the motor mounts in at least one of the pictures, they come up from the K member.
  8. okibono
    okibono Member
    cali
    thanks! I saw the motor mounts, and I was wondering what type of mount are they going to use to mount to the motor? And was there going to be any adjustablility within that mount?
    thank again....
  9. maverickdvm
    maverickdvm Member
    Michigan
    We haven't picked our motor mount yet. I'm waiting until you do all the research on it and then tell us which one is best. :burnout: Anyhow, we aren't to that point yet. So far all we have done is get the exterior paint, sonic check the block and choose heads and other parts. I'll be making a parts order this week or next. We will be using at least a mid plate for sure.
  10. maverickdvm
    maverickdvm Member
    Michigan
    Okay, I have the final prices. Where did you get those ones? The complete kit price is $2377 for fox type spindles and $2477 for SN95 type spindles. The struts are included in that price. You can get a caster adjustable a-arm which would add on another $100 if that was of neccessity to you. The k member is the same as the 64-70 Mustang, the struts and a-arms are similar, but Maverick specific. And then whatever brakes you choose, so ~$3000. It is technically bolt-on, the only hard part is getting the old stuff unbolted!
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Which spindles did you go with? Anyone know what the advantages are of the SN95 over Fox Spindles?
  12. maverickdvm
    maverickdvm Member
    Michigan
    We went with the fox spindles. They are lighter for drag racing. The SN95 spindles allow you to use factory 13" brakes and ABS.
  13. 1badmav
    1badmav Member
    What brakes and struts??Are they adjustable??I was quoting with Aftermarket front discs and Adj struts.. Im really interested at 3000 if I can get all adjustable stuff...Thanks
  14. maverick1970
    Missouri
    Sarah, was this mocked up with an engine? It appears this setup will require the use of a rear sump oil pan, correct?
  15. maverickdvm
    maverickdvm Member
    Michigan
    Yes, rear sump pan will be needed(one of the advantages). They have used that K member in quite a few Mustangs so far, just never a Maverick. It has not had a motor in it yet, it will be a 393C.
