Firewall to Hood seal...
Discussion in 'Technical' started by MNTony, May 10, 2012.
  1. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Hi guys,
    Do any of you have a picture of a 72 with the hood seal in place? I just got one from AutoKrafters and it is full length out of the box from one edge of the hood to the other. But there are no clips or holes beyond the center section and there is no way to mount the ends. I think that this should be cut down, but if anyone has mounted this full length I would be curious to see how you did it. If you cut it down, I'd like to see where you cut it for the stock length. Unfortunately, my car never had one when I bought it and I am flying blind.
  2. tody
    tody Member
    cologne, germany
    i cut it down:
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I glued the rest of mine to the cowl and ran it full lenght.
  4. maverick75
  5. Joe Dirt
    My car had clip holes and my AK trim had then also. Mines full length and tucks under the fenders unless ive forgotten ill check today
  6. Craig Selvey
    The correct way to mount it on a 1972 is to cut it down so it only mounts to the raised portion of the cowl.
  7. mojo
    What abt 73 models?
  8. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Thanks guys. I think that I'm going to take the easy way out and just cut it down like it was originally.
  9. Dave B
    73 & up, go all the way......
  10. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Typical of a slacker. If you cut it down then why even put it on? water is still going to get in there. guess its going to come through the hood snorkels anyways. Does it really matter since it never leaves the garage? :rofl2:
  11. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    You know that I'm trying for the 100 point restoration here Ryan! And it leaves the garage...it's in the way sometimes and I have to push it into the driveway to make room.
  12. Ryan
    Ryan Ford Addict
    Phoenix Az.
    You must have pushed it outside last night and caused the storm to blow in.
  13. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I wouldn't talk oil slick boy...:biglaugh:
