first passes with 418w
Discussion in 'Drag Racing' started by stroker mav, Jun 8, 2015.
  1. stroker mav
    stroker mav Member
    canton, ohio
    1964 country sedan,1933 essex terraplane
    I took the mav out for some shake down passes at our local 1/8 th mile track.Foot brake at 2500 it went 6.38@ 108 mph,trans brake@ 2500 6.34@108,and tran brake @4700 6.40 107 spun to much air in slicks and trans brake@3700 6.32 @108,and 60ft of 1.39 shifting at 7000 rpms. Now that I know it goes straight and doesn't do anything stupid ,I plan on leaving @4500 on the trans brake and shifting at 7500 with 8lbs of tire pressure.
  2. Krazy Comet
    Congrats, 108 in the 1/8 mi is really movin' on!!!
  3. Rick
    Rick G8I operations
    Ocala, Florida
    That's getting it done, interested in seeing how much picks up spinning it higher.
  4. stroker mav
    stroker mav Member
    canton, ohio
    Rick,I may have ask you before but what does your car run in the 1/4 mile @ what rpm,what size rear tire ?
  5. junrai
    junrai Member
    rancho cordova ca
    `thats MOVIN in the 8th mile great job cant wait to be able to say I took my car out for the first time
  6. z28th1s
    Lynchburg, VA
    Nice!!
  7. hectorsalinasx
    hectorsalinasx Member
    1969.5 Maverick
    Thats fast....can you share the details on that 418w setup??
    Congrats!!!
  8. stroker mav
    stroker mav Member
    canton, ohio
    Dart block, trick flow R 210 runner ,super victor,solid roller,950 quick fuel carb,13 to 1 compression.
    Maverick Dude likes this.
  9. airford1
    airford1 Member
    San Dimas, Ca
    That's Comp license time. FLYIN
  10. Rick
    Rick G8I operations
    Ocala, Florida
    We have close to the same setup although I have the 225 Highports with a tiny 750 carb. Been leaving at 4800 on the brake but could stand to loosen the converter it's only flashing to 5400. Last time out was a 9.87 @ 135 , 6.27 110 1/8 with a lazy 1.37 60, shifting at 6800, going through at 7000. Tire's are 32 14.5w 12#
    tbirdz12 likes this.
  11. stroker mav
    stroker mav Member
    canton, ohio
    I only had one 9 in pig and it was a 5.38 it worked ok for my 347 left at 4500 and shifted at 6800 and went threw at 6800.We did some numbers with the 418w and it looks like it could go threw the traps around 8100 to high for my taste. Your 4.56 or a 4.86 my be a better gear, thats next on my list before I go 1/4 mile, thanks for the info. I only have one question why the 750 carb ?
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    R U taking it to Quaker? I would like to see it run.
  13. stroker mav
    stroker mav Member
    canton, ohio
    Yes but just for a test and tune to see what rpm it will go threw at before I change gears .
  14. Rick
    Rick G8I operations
    Ocala, Florida
    I started with the 750 off my old car when I converted to E85. I do have a 1050 Dominator that I ran for a while and it was ok but not as responsive as the 750. The 750 produced a much better fuel curve. What I really need is a 950 or 1000 cfm 4150 based carburetor. The 4150 is just giving me a lot more velocity and signal. As they say, it's all part of the struggle"
  15. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    With 4.56s & a tire over 30 in tall once you get it dialed in,should go mid 9s if it hooks.4.22s & a shorter tire could also do it.I`m going to petersburg va this wknd with a freind from work to help him with his car,fox body w/ a 363 & a c4,hoping to go low 10s.
