First time at the track...
Discussion in 'Drag Racing' started by facelessnumber, Jun 4, 2012.
  1. John Holden
    John Holden Member
    NJ
    Ford traction locks are notoriously weak though. I've broken several over the years, 8" and 9". The side covers break around the ring gear bolts.
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Didn't know that. I probably don't put a lot of stress on it with the C4.
  3. John Holden
    John Holden Member
    NJ
    Yeah everything I've ever had was stick shift which shocks everything alot more.
  4. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Broke two in that area in my 79 f150 4x4 with a automatic,yup the one in my Comet makes me nervious......
  5. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I forgot to go back and correct -my trap speed wasn't spectacular but it sure wasn't ~75 MPH. Here are my timeslips from that night.
    And even better, here are some videos from that night!
    This was my first run ever, and it wasn't too bad. I let the trans shift a little early, had a burned plug wire, but mostly my problem was traction. I have none. Stock high-geared open diff. But I left the line easy and didn't spin too bad on this one. Every run after this I tried to launch a little more aggressively, and each one sucked just a little bit harder...
    This one... Pure shame right here. Here you can clearly see the source of my weak times, that stock "peg-leg" rearend. It's got to go. But the worst part is when I staged with my rear wheels. I have no excuse for that, I just sucked.
  6. Jsarnold
    '72 Sprint
    Facebook says the vidoes are unavailable - not authorized to see it.
  7. olerodder
    olerodder Member
    NorCal
    X2, can't access the videos.
  8. facelessnumber
    Memphis, TN
    '71 Grabber
    Bah, lame. I'll see if I can download them somehow and put 'em somewhere else.
  9. cody674
    cody674 Member
    1972 Ford Maverick
    make the video public where everyone can see them
  10. facelessnumber
    Memphis, TN
    '71 Grabber
    Unfortunately they weren't mine so I have no control over those settings. However I did just download them from Facebook and re-upload to my Youtube account.
    So... Videos are fixed. (y)
  11. Jsarnold
    '72 Sprint
    Can't wait to see it with some drag radials and lsd. :dancing: I'm guessing you'll be in the 12s.
  12. yellow75
    Tillamook Oregon
    Once you get the car to hook up it will be a whole different world, it will be like driving an entirely different car, front end will lift and it will lay you back in the seat.
    I can see the smile on your face now
  13. facelessnumber
    Memphis, TN
    '71 Grabber
    Inspiring words... I need to get to the junkyard and start looking under some Explorers.
