First tme at the track!!
Discussion in 'Drag Racing' started by lynhrt210, Oct 1, 2011.
  1. JHodges
    JHodges thumper
    Dora Alabama
    can you post the timeslip up. I personally have never seen a car do good at the track with an edelbrock carb. The converter seems to be tight and the 60ft is terrible. I would expect a mid 1.70 60ft and the car should be in the mid 12's with the combo you have with a different carb and converter
  2. olerodder
    olerodder Member
    NorCal
    Fordmaster169,
    That was only half of the story, I tried to get it with an "easy-out" and broke that off in the block as well....................it's now time for me to call "The Bolt Removal Guy"...................and yes, I had more than three glasses.
  3. darren
    OH no. Dont that once to often. Last one I did our machinist came over and broke up the easy out then did the removal. Took hours. He told me not to do anymore. Just call him its easier this way. :rolleyes::)
  4. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Ok my slip...
    Reaction... .4344
    60Ft----2.2384
    330----5.9858
    1/8 et----9.0159
    1/8 mph 81.43
    1000 et 11.6428
    1/4 et----13.9120
    1/4,----96.13
  5. JHodges
    JHodges thumper
    Dora Alabama
    My cousins full weight 93 gt hatch has a flat top 306 with an f303 cam, gt40 heads, stock headers and a explorer intake, aftermarket clutch with a stock t5 goes 8.50's at 82 in the 1/8 with a 1.90 60ft leaving at 5k on bone stock suspension with old old 26x10 et drags
  6. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Good advice...but a quicker Reaction Time will not make a difference in his ET. Has no bearing on it. ET doesn't start until the beam is broken...RT is just the time diffence between when you COULD have left, and when you DID lol. A good example of this is if you watch qualifying for fuel classes on TV...often, they will not leave right when the tree goes green...they have horrible RT's...but their ET is still the same as if they made a competition pass...
    Just some info...
  7. Rick
    Rick G8I operations
    Ocala, Florida
    So then you agree that a faster RT will break the beam quicker.
  8. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    It doesn't matter if you have a .001 or a 1.001 reaction time....it will not change your ET printed on your time slip at all. There is NO corelation to Reaction Time and Elapsed Time whatsoever. If you don't believe me...next time you go to the track...intentionally be dead late on the tree...wait until you see a whole lot of the green...and then run it out like a normal run. ET will be what it's supposed to normally be. Your time does not start when the light turns green...it starts when you break the beams.
    Now 60 foot time is a whole other story lol. Get that down, and consistent, and you can go rounds. And going rounds is what it's all about. Consistent 60' times is one of, if not THE, most important times to try to get consistent if you want to race and win.
