FiTech EFI Installation
Discussion in 'General Maverick/Comet' started by bmcdaniel, Mar 23, 2016.
  1. mavgrab302
    I put a t-stat housing on mine that has a spot for a sensor, now I can use the intake for the fitech sensor.
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Got the install finish . Runs much better than carb. need to drive it more so it can learn more and got smarter.
  3. bmcdaniel
    Today's the first chance I've had to work on mine. Mounting the fuel command center now.
  4. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    did not use the command center used frame mounted pump and return line.
  5. mgabski
    mgabski Member
    1973 Maverick
    So in that mean street contest I won a fuel command center. Because I won that, I ordered the 1200 hp power adder kit. I had 10% off summit plus the rebate so that took about 300 bucks off total. Summit says the unit should be in stock monday. Hopefully. Also ordered a few odds and ends. Due to my lack of carb knowledge I expect to see fairly large gains with this conversion.
  6. mgabski
    mgabski Member
    1973 Maverick
    What are you doing for the vent line? I saw mixed things online about the vent line having liquid fuel come out, causing a pee trap and car does not restart. I've got an idea of using an oil catch can with a breather in engine bay. Minimize line needed so less of a chance of that issue happening.
  7. bmcdaniel
    The vent is more than just a vent, it's also a safety valve in case the float sticks in the command center. Otherwise your mechanical pump could dump a bunch of fuel on the ground. I'm running a 3/8" aluminum line back to the filler neck.
  8. bmcdaniel
    The only people I read about having venting issues were 2 guys with Chevelles. I think they were attaching the vent line to the fuel tank vent and messsing things up. My theory anyway.
  9. mgabski
    mgabski Member
    1973 Maverick
    Maybe. I may just tap my filler neck and run the line back. Just don't wanna get stranded that's all.
  10. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I just ordered the 1200hp kit. Won't ship till the 25th
  11. bmcdaniel
    For awhile I'm gonna carry a carb in the trunk. Just in case...
  12. mav man
    mav man Member
    wi
    70mav
    Now that's funny:lolup:
  13. bmcdaniel
    Just me I guess. 3 years ago I installed EDIS ignition, I still carry spare coils and EDIS module in the trunk. I also have no reservations about jumping in the car and driving half way across the US.
    Static and Craig Selvey like this.
  14. mgabski
    mgabski Member
    1973 Maverick
    Where did you order from
  15. 7D2 Grabber
    7D2 Grabber Member
    I ordered from summit racing. There is a back order everywhere on most of their kits.
