FiTech EFI Installation
Discussion in 'General Maverick/Comet' started by bmcdaniel, Mar 23, 2016.
  1. 71gold
    what PSI does it operate at?
  2. bmcdaniel
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    A friend of mine just ordered this for a smallblock Chevy 383 stroker.
  4. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Those with an intank pump Are you running an additional filter other than the one by the tank? Also what size are the return and feed lines on the carb? Mine should be in next week and I'm trying to get a head start on the fuel lines and fittings.
  5. bmcdaniel
    For the 600 hp system they recommend 3/8" (-6AN) supply line and at least 5/16" (-5 AN) return line.
  6. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    On my son's unit he is using external pump with filter before and after the pump -6 supply and -5 return .
    He is also having a intermittent stalling problem no time as of yet to fix the problem.
  7. 7D2 Grabber
    7D2 Grabber Member
    Is it a -6 ORB? -6 to 3/8 pipe?
  8. mgabski
    mgabski Member
    1973 Maverick
    I started my install yesterday. Had a dumb mistake that set me back some time. Had to change my studs out for my manifold, dropped a nut in engine, and I don't have any magnets at home besides a small pocket screwdriver. Ended up dropping the screwdriver in there also. Lol. Went out and got one at advanced auto and got it out, but wasted alot of time.
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    You were lucky. Anyone who's worked on a lot of engines probably has for worse stories than that. I know i do. Lol
  10. mgabski
    mgabski Member
    1973 Maverick
    Lol I work on tons of stuff all day at work, just generally make the stupid mistakes in my own cars. this is typically what i'm doing. [​IMG]
  11. 71Mavrk
    71Mavrk Member
    Nevada
    I did something similar to this right after the tank.
    http://www.summitracing.com/parts/aei-12316
    Micah
  12. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Any updates? How's it doing after some driving?
  13. mgabski
    mgabski Member
    1973 Maverick
    Mine is great, night and day difference. I really enjoy driving my car now. It was fun before but it just never ran right with the carb. Its the best money I've spent on my car.
  14. bmcdaniel
    I was still having a problem with the idle hunting and not snapping to the set rpm when I let off the throttle. Spoke to FiTech tech last Friday and got the IAC set right. I need to adjust the timing curve in my EDIS ignition. I have the EFI set for 850 rpm idle but the ignition tries to advance starting at 800 rpm, I think they are fighting each other. I've revised the curve on my computer, just haven't had a chance to upload to the ignition yet. I'm away on vacation until Sunday.
  15. 71gold
    this is the reg. and return I run on my Atomic (in tank pump), is this something that you Guys might be able to use on the FiTech?
