Flasher flashing too FAST
Discussion in 'Technical' started by rickm, Jul 15, 2012.
  1. Dave B
    What?? :hmmm: I didn't read between the lines....:oops:
  2. Joe Dirt
    What about running 2 electronic flashers in series? Just a though
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Ground issue. When the socket isn't grounded and the light still flashes, it's grounding back through the tail light side.
    Somewhere, you have a ground issue. Could be front lights, could be in the rear.
  4. bmcdaniel
    That's why I have ground wires from each tail light housing to the body at the back.
  5. rickm
    rickm Member
    Owosso Mi
    Just got home and was thinking about see if there was any current bleeding from the socket with a meter tomorrow. Should your side marker lights be flashing, both of mine do ?
  6. blugene
    It has been a long time since I have seen mine even on lol.. I do not recall seeing the sides flashing on my 73..
  7. Dave B
    Some cars do, some don't. I don't remember the exact details.
  8. rickm
    rickm Member
    Owosso Mi
    I put my meter on the socket this morning and found 1.7 VDC bleeding , so I guess it's buy a new socket time. Thanks for all the help Rick
  9. ford84stepside
    Berry Alabama
    No, side marker lights on a Maverick do not flash. Another indication that you have a bad ground somewhere, the T/S is using the running lights for it's ground.
    Unplug your front T/S on each side, do not take out the bulb, just unplug it at the plug, and see if the rears flash normaly. I had a front light short out in the wiring, and it was doing something simular. I replaced it with another one and everything started working fine....
  10. Craig Selvey
    Actually.....they DO flash. We talked about it on here before. Maybe it was on the old, old message board.
  11. rickm
    rickm Member
    Owosso Mi
    I replaced the 2 outside sockets (the originals) and the blinkers work nice and slow. But the 2 side marker lights flash too, which I'm OK with. Thanks again for all the help Rick
  12. Craig Selvey
    They are suppose to, so you are fine.
    See you at the MCCI Roundup Nationals. It won't be long now!!
  13. mercgt73
    mercgt73 Member
  14. ford84stepside
    Berry Alabama
    Well Craig, now you've got me thinking I have a problem! Well, maybe I do, but I'm talking about the car.:D
    Mine do not flash! Never have, as long as I've owned the car. Front and rear work fine, but side markers glow, not flash at any time!
    Maybe some were wired different?:hmmm:
  15. bmcdaniel
    One time, comparing my 70's side markers to a friend's 72 we found that my markers always flashed at the same time as the front and rears. His worked the same way when the headlights were off. Turn on the headlights and his side markers flashed on when the front and rears were off. Strange...
