floorpan rust
Discussion in 'Cosmetic' started by 71mavkidd, Jun 11, 2008.
  1. JCWGrover
    JCWGrover Member
    Rochester MN
    1976 Maverick Stallion
    It is not always necessary to remove the entire cowl top. I've had good luck with just removing the fenders, and cutting the cowl open there, patching, and weld it all back up!!
  2. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    does it matter what the doner car is for a replacement cowl?
  3. Acornridgeman
    Wisconsin
  4. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    can replacement mustang cowl panels be used on a mav?
  5. Acornridgeman
    Wisconsin
    You can buy a kit to replace the "hats" as they are called. As far as a complete Mustang cowl - I know there are size differences between Mavericks and Mustangs so I don't think it would be a direct swap without doing some fabrication. Most repairs can be done to the rust holes and the original cowl can be saved.
    I like Joe's idea of cutting open the sides and welding them back in after the repair is made to the hat. :thumbs2:
  6. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    once the cowls are fixed can a screen or mesh be put on the underside of the grille part so that more $hi+ doesn't fall in there and cause us more problems.
    And does anyone have any pics of a side cut out job i am kinda wondering just exactly where these cuts should be made.
