Fluid on Intake
Discussion in 'Technical' started by Snoho73, Jun 12, 2026.
  1. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    I have a small puddle that sometimes form on my intake. Drivers side just in front of carb. Seems to be coolant, any ideas?
    Mike
  2. TeeEl
    TeeEl Senior Member
    Colorado
    Check your heater hoses and fittings...
  3. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    Yah, forgot to mention all hoses are tight and checked for leaks with paper towels. Water temp sending unit also checked OK. So all fittings appear to be not leaking. I can not see fluid when cold/hot and running or shut off after reaching running temp. Puddle development is not consistent, does not appear all the time. Oh, forgot new radiator and cap too.
    The intake numbers indicate it is a marine unit, could there be a thin wall near this spot? weeping?
    Mike
  4. TeeEl
    TeeEl Senior Member
    Colorado
    Have you checked the torque on the intake manifold bolts?...
  5. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    Not before your note, they were fine.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    Keep an eye on it. I hate to assume the worst, but if everything else checks out good, it could be a casting defect, which would require replacing the manifold...
  7. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    Broke down and resealed all ports on top of manifold. No puddle yet.... Monitoring...
    Thanks for the exchange.
    TeeEl likes this.
  8. Snoho73
    Snoho73 Member
    Snohomish, Wa
    '73 Maverick LDO
    Well no puddles to date, so must have been a weeping port thread.
    TeeEl likes this.
  9. TeeEl
    TeeEl Senior Member
    Colorado
    The timing of your thread is a crazy coincidence. A week ago, I noticed a tiny puddle of coolant on each side of my timing cover. Couldn't see where it came from, but figured the water neck might be the most likely culprit. It is the kind that uses an O-ring, not a gasket. So I tightened the bolts, and cleaned up the puddles. A week later and after driving the car over 100 miles. there's no sign of any leaks...
