Flywheel Grinding
Discussion in 'General Maverick/Comet' started by tonyj71mav, Oct 7, 2011.
  1. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    fordman is right you should always seat the converter on the tranny then put it in if you pull the tranny to the motor you will ruin the pump
  2. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    trans
    PA makes a bellhousing that fits both flywheels.
  3. tonyj71mav
    tonyj71mav Member
    Upper Marlboro, Maryland
    Who is PA? Brand name, vendor ???????
  4. Dave B
  5. tonyj71mav
    tonyj71mav Member
    A .100" starter shim took care of problem. Started up with no grinding at all. If you take what 71Gold said about the snout being longer in the 164 tooth converter then it all adds up. I added a .281" spacer +.100" shim = .381". The 164 converter snout was .375 longer.
    Thanks, TonyJ
  6. bmcdaniel
    So what are you gonna do about the .006" difference? :D
