Ford 200 engine MPG
Discussion in 'Technical' started by 19MAVERICK72, Nov 30, 2007.
  1. newtoford
    newtoford Member
    New Castle Delaware
    since were on the subject maybe i can get some opinions
    im droping an a 68 302 (with points right?) ive never delt with points so you guys are going have to take it slow lol
    my I6 mav has factory electronic ignigtion
    how should i wire it up?
  2. PaulS
    Pertronics is a good way to change to electronic.
    If you want to run points you are going to need a Dwell Meter and a good set of wire thickness gauges. Set the points with a wire gauge to .017 to .021" gap when the points rubbing block is on the hump of the distributor cam lobe. Then it will start and run (you have to set timing after setting points because the points will affect timing).
    With the dwell meter you want to set the points so the dwell measures 28 to 32 degrees and the closer you set iot to 28 degrees the better the performance will be. Remember that if you change the dwell or point gap you have to reset your timing too. A little (very litle) lube on the distributor cam, a couple of drops of oil on the wick under the rotor and a couple more drops of oil under the breaker plate to lube the advance weights. Set your plug gap as close as you can get to .028" and keep the idle smooth using Autolite plugs. Points don't work well above 4800 rpm unless you get the hi perf points sets and the heavy duty points start to bounce even sooner than the "normal" points. The high perf points are usually good to about 6500 RPM. Match the points with what your engine needs - the High Perf points are expensive.
  3. PGARFDS
    PGARFDS Need more room!
    Near Tulsa
    702dr, 2-72 302 Grabbers, 72 302 2dr., 72-200 2dr., 73Grabber, 74 2-dr, V8 4spd Stallion, & rusty Stallion
    Factory 74 2dr 250 auto gets all time average of 16.7.
    The last 4000miles(moderately short trips) got an average of 15.4
    Highs of 20.5 and 23.8 (all highway 60+mph)
    Lows of 11.8 and 12.0
    New to Ford? Just go to the salvage and get a factory(duraspark) distributor from a 302.
  4. newtoford
    newtoford Member
    New Castle Delaware
    would something from an 80's 5.0 do the trick? thats probably going to be the oldest 302 in any yard near me
  5. scooper77515
    Why would you care? Plan on swapping out your built 302 for a stock 200? That would probably be the first on this forum...:huh:
  6. 19MAVERICK72
    19MAVERICK72 Dan
    Houston
    1972 Ford Maverick
    Never!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I have the 1970 remember:D
  7. scooper77515
    Well...YOU were asking:p
  8. Jamie Miles
    Alto, GA
    I've had a few
    Just get a Duraspark distributor from a late 70's 302. It will literally plug right in in place of the 6 cylinder distributor. I personally have tried the Pertronix twice, both of them burned up within 10,000 miles. The last time I had to walk 3 miles, never again... "Fool me once..."
    Can't see why anyone would prefer points over electronic ignition on the street. My car had more power and better gas mileage when I went from points to electronic. Runs a hell of alot smoother, too with a hell of alot less maintenance.
  9. bmcdaniel
    Sounds like something else in your car was not correct or compatable with the Pertronix. I can see one failing on it's own but not two.
  10. Jamie Miles
    Alto, GA
    I've had a few
    Don't know what could have been wrong. They were on a switched 12 volts source with an MSD Blaster coil. I won't use one again regardless.
  11. newtoford
    newtoford Member
    New Castle Delaware
    would a 1980's 302/5.0 give me the correct dizzy?
    thats probably the oldest ford engine i'll be able to find in these parts
  12. bmcdaniel
    It would have to be early 80s before roller cams came into use, 85(?) and later had steel gears that would tear up your cam.
  13. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    will the 76 electronic distributor work on my 71? and what all differences will it have compared to points? what other things are there to do to get better gas mileage on a stock 200?
  14. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    My 200 I6 with power steering and A/C got 24mpg when I brought it home from Florida to Maryland and after getting it home normal driving back and forth to work every day it get right around 20mpg with the A/C blowing and P/S, without the A/C blowing it does get a little better but not much. The 302 that is in the latest Maverick I bought is getting around 17mpg. So I have been driving it back and forth to work more than the I6. 17mpg and I get V8 power and get to bang gears along the way or 20mpg and I get to relax and listen to the stereo. Man life is good. I got a Maverick for all occasions. I can swap back and forth when ever I want and enjoy the drive either way.
    Now on the other hand it is snowing out there right now so after I drive home tonight (in the V8 Maverick) I will be parking both Mavericks for a few days and driving my truck because Maryland salts the hell out of the roads and I don't need salt up under either one of my Mavericks to rot them out.
  15. stmanser
    Davenport, Iowa
    i had a 170 in my car with a 3speed. when i drove it from kentucky to arizona in the dead of summer, i got 37mpg, that was with a 2bbl carb driving 65 mph
