Ford Fusion steel wheels
Discussion in 'Wheels and Tires' started by Racer_X, Apr 20, 2012.
  1. 1973Ford
    1973Ford Member
    North Scituate, RI, USA
    1973 Maverick, 76 Maverick
  2. GRABBER70
    GRABBER70 Member
    wisconsin
    1970 maverick grabber
    does anyone know if theres any newer mustang wheels that would fit a maverick WITH OUT spacers?? i like a lot of the newer wheels but i dont want to use spacers. im looking for bolt on and go.
  3. NorCalMaverick
    NorCalMaverick Member
    Pinole, Ca
    1974 Ford Maverick 2 Door
    just curious what IS the offset for a, 74 maverick?
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    There's no specific "offset" for a Maverick. I don't expect that any wheels made for a front-wheel drive car would fit properly.
    You should be more concerned with back-spacing than offset (rear-wheel drive wheels). You can run anywhere from a 3-1/2" backspace to a 4-1/4" backspace without modifications, providing that the tire width is compatible. A typical 14x6" Ford wheel has a 3-1/2" backspace, while a 14x7"has a 4-1/4".
  5. NorCalMaverick
    Pinole, Ca
  6. NorCalMaverick
    Pinole, Ca
    what's the widest wheel I could fit with no mods, I'd like a 9-10 but if not 8 is good
  7. Dave B
    Go back to one of the other threads you posted in, and look for the link that will answer all your questions.
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
  9. NorCalMaverick
    Pinole, Ca
    ok I see, I just found some 15X8 cragers with a 4 inch backspace but 10's are starting to seem out of the question
  10. Craig Selvey
    Yes....10's are out.
  11. baddad457
    I'm running 15 x 10's on the rear of mine with a 5" backspace, tires are 295/50's. Only "mod" I did was add helper springs to stiffen the stock springs and roll the fender lips to avoid scuffing my tires should they ever rub. But they never do. Wheels are Wheel Vintiques Chevy truck repops with a dual bolt pattern. They match the fronts which are 70's vintage 15 x 8 Mopar cop car wheels. If I had run 275/50's, the helper springs would have never been needed.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No disrespect, but I am doubting the "5-inch backspace". That would rub the leafsprings with a stock Maverick rearend. When you say no mods, I assume a stock rearend.
  13. baddad457
    You can doubt all you want but my wheels DO have a 5" backspace,I ordered them that way, I checked em when I received em, and I put them on myself, as I also did the rearend swap myself. There's a half inch clearance between the sidewall of the 295's and the leaf springs. You can also gain some room by loosening the U bolts and using a prybar, moving the spring inboard while retightening the U bolt. And as I recall, I'm not the only member here that's running tens with a 5" backspace.
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I still doubt it, because when I had 15x8s with a 4-1/2" backspace, I had to run spacers to prevent rubbing the leafsprings with only a 235 tire. So if a 4-1/2" rubs, a 5" inch won't even turn on a stock Maverick rearend and suspension. The 4-1/4" backspace I am running now only leaves a finger's width of space between the leaf spring and the 235/60-15s (no spacers).
    Based on these facts, the only probable conclusions I can come to are:
    1) Your backspace is not really 5"
    2) Your rearend is not the stock width
    3) There must be a heck of a wide tolerance on Maverick 8-inch rearend widths.
  15. dav
    dav Member
    wisconsin
    1970 maverick,tdi jetta,super duty
    ok I just put a 1980 monarch rearend in my 1970 mav today. I bought a set of mustang bullit wheels 17x8. with 5.75 backspacing, they miss the leaf springs by 1/4". I had to trim the bump stop bracket, but that is it. but with the stock rearend I would have needed about 1.25" spacer. hopefully everything clears up front!
