Ford/Mercury seats??
Discussion in 'General Maverick/Comet' started by littlekentucky, Jul 1, 2018.
  1. littlekentucky
    littlekentucky Living the Dream
    Minnesota
    1971 Maverick (2)
    23824849-6895-4322-A4CF-4BF8C577159B.jpeg 24416D64-7444-43F0-ACDF-9E1747D537ED.jpeg Do these look like Comet or Maverick buckets?
  2. 71gold
    they look like LDO maverick seats. I have only seen them in lt.blue and tan...:yup:
    littlekentucky likes this.
  3. Krazy Comet
    Dismal Swamp
    I believe '75 & maybe '74 Comet GT had those available in black.
    At some point the Mustang type seats used in '71-'73 were discontinued.
  4. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Yup, LDO Mav/Comet bucket seats - looks like they used to be tan and then sprayed black.
  5. CaptainComet
    Those were made for later cars that had the floor raised near the passenger side of the trans tunnel. They had to squeeze a catalytic converter in there.
    The passenger seat is lop-sided, one track higher than the other. Regarding how to make these work in an early car, see this discussion ....
    http://mmb.maverick.to/threads/cat-hump-bucket-seat-tracks.80862/
    Especially note the extended front mount on that one seat track. You could move that back to make it match the other tracks. You will need to come up with a spacer between the track and the seat bottom to level that seat.
    There also should be small and large riser blocks for the driver side inside seat track. If not, some spacers could be fabbed up. The floor pan is lower next to the trans tunnel than it is outboard. If using the existing seat track holes in the floor pan, double check that the driver seat is centered behind the steering wheel. I believe this combo should be OK. I mixed tracks and different seats and that combo is offset a bit without making an adjustment.
  6. littlekentucky
    Minnesota
    1971 Maverick (2)
    I really appreciate the insight!
