Ford Perf Intake Manifold
Discussion in 'Drag Racing' started by Northern, Jul 15, 2015.
  1. Northern
    Northern Member
    '74 Maverick
    Does anyone have experience with the Ford Performance dual plane intake? I need a carb, so I might as well get a 4 barrel...so I need an intake too. My 3 primary choices are below, but I just herd about the FP intake, and am starting to lean that way.
    Weiand Stealth
    RPM air gap
    Ford Performance Dual plain
    I'm not running 10's...but like everybody else, I'm building it as I go.
    Thanks for your inputs guys,
    Northern
  2. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Any one of the three would be a good street intake. It is not until you get a real good set of heads and more aggressive cam timing that you would notice any performance difference between the three.
  3. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I have the Weiand Stealth on my 302 very happy with it
    greasemonkey likes this.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    The stealth is an excellent choice for a stock engine.
  5. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I have the Weiand Stealth on my Comet. It's a good intake for street use, stock to slightly modified. It is a dual plane intake.
    Krazy Comet likes this.
  6. Krazy Comet
    Have the Weiand Stealth 8020 on my Comet as well...
  7. Northern
    Northern Member
    '74 Maverick
    Thanks guys, glad to hear good results from the list.
  8. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    Both the Stealth and RPM air gap are a better intake than the ford performance! they will make power to about 6500
    above that you would need a Victor JR!
  9. junrai
    junrai Member
    rancho cordova ca
    my car now has a weiand stealth as well runs pretty good rpms wind up VERY fast not sure if its the intake or the cam but rpms come up faster than it sounds
  10. Rick
    Rick G8I operations
    Ocala, Florida
    Plan for the future, RPM Air gap or Victor Jr..
  11. Mavit
    Mavit Member
    Prince george bc
    Your two plain intake will pull good on the bottom and whined up quick but the power will fall off above 6500'togo above that you need a good open plenum intake like the Victor J R!
    Edelbrock did a real good job on the Victor JR it pulls real well at lower RPM but will let the engine spin up past
    7000 RPM.
  12. Northern
    Northern Member
    '74 Maverick
    How do you think that Victor Jr would work under an EFI, like the Edelbrock E-street or Holley Terminator?
  13. Mavit
    Mavit Member
    Prince george bc
    I'm not familiar with the Edelbrock E street but I have seen a Fast EZ EFI on a 347 with a victor JR that runs smooth as a kitten on the street and turns low 11 second times at the strip!
