Ford Toploader 4-speed swap
Discussion in 'Transmissions' started by seth, Jun 6, 2010.
  1. tody
    tody Member
    cologne, germany
    good to know, thanks :thumbs2:
  2. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    going back to my original post do any of you know if long tube headers will work with with the 164 tooth bellhousing that goes with the toploader?
  3. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Anyone have any idea?
  4. PaulS
    I couldn't find any long tube headers to fit my 1966 Mustang with a toploader but then I was looking at swap headers fot 351
  5. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    so do you think it would have any clearance issues? do you know if the bell housing is any larger then the c4's?
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Dan Hines had Hooker 6901's on his car with a top loader...
  7. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Okay thanks so at least i know it will work:)
  8. spork1o1
    spork1o1 Member
    Michigan
    The top loader will bolt to a 157 tooth bell housing as well.
  9. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    I have hedman long tube headers with a toploader, I also have a lakewood scattershield that can use either 157 or 164 tooth flywheels.
  10. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    okay thanks, so that shouldn't be a problem.
  11. John B
    John B Member
    Ontario, Canada
    '73 Mav
    Could one of you toploader guys please post the number of the Hurst shifter installation kit that you're using? They don't show one for Mavericks. I presume that most of you are running CompetitionPlus shifters? Thanks. John B
  12. spork1o1
    spork1o1 Member
    Michigan
    The shifter location on the tail shaft will determine witch installation kit you need. The one in my earlier post is a rear mount tail shaft out of 64-73 mustang, so that is what I ordered the kit for.
    tail shaft id
  13. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Do you guys know what are the prices i should be looking for when locating the items for the 4 speed swap. such as clutch petal assembly, clutch linkage and used Toploader/bell housing? I just need to know what prices i should be looking for.
  14. spork1o1
    spork1o1 Member
    Michigan
    Ive seen complete clutch pedal z bar setups go for $200 to $500.
  15. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Thanks for the info everyone I'm just weighing the pros and cons between the T5 and toploader trying to find out the round about difficulty and price of each one.
