Ford unveils radar-based Collision Warning with Brake Support system
Discussion in 'Ford Industry News' started by Mav.bot, Oct 8, 2008.
  1. Mav.bot
    Mav.bot Member
    Filed under: Safety, Tech, Ford
    Click above for high-res gallery detailing Ford's new radar-based safety tech
    Just a day after unveiling its innovative and controversial MyKey system, Ford has come back with another piece of new technology, this time safety related, that will start appearing on some 2009 models. It's called Collision Warning with Brake Support, and it uses the radar system that makes Adaptive Cruise Control possible to detect what's in front of the car. If the system senses contact with something might happen, most likely another car, it will at first sound an audible alarm and activate a warning light. At the same time it will "precharge" the brakes and activate a brake-assist function in case the driver needs to slam on the brakes. While Ford doesn't give the details about what's exactly happening, it sounds as if this radar system will monitor the distance between your Ford and what's in front of you, and if a collision is deemed imminent will effectively get the brakes ready for a panic stop. We're told the technology will begin on appearing on select Ford and Lincoln models for 2009, along with other radar-based technologies like the aforementioned Adaptive Cruise Control that debuted on the 2009 Lincoln MKS and BLIS, a blind spot warning system. Check out video of the Collision Warning with Brake Support after the jump along with Ford's official press release.
    Gallery: Ford Radar-Based Active Safety Technology
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    [Source: Ford]Continue reading Ford unveils radar-based Collision Warning with Brake Support system
    Permalink | Email this | Comments
    More...
