Frame Connectors ?
Discussion in 'General Maverick/Comet' started by John W, Oct 15, 2013.
  1. Mavman72
    lh_subframe_connector_front_view_original.jpg Heres a few more pics for you... rh_subframe_connector_front_view_original.jpg These are the alston connectors on my mav project.
  2. Mavman72
    These are the chassis engineering ones I installed on a friends mav. They fit well out of the box...Some trimming and tailored fitment can tuck em in tighter if you want.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Note on Chassis Engineering sf connectors. They will not work with the later model cars with pedal park brake. The Assy under the car is in the way. And while I am here. Mine are no longer in production.
  4. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I have wondered this too.
  5. Bryant
    i strongly recommend subframe connectors for street driven cars. every car ive had that ive put them on has had drastic improvements in many areas. the doors close better. the brakes respond faster, the turning response increases, the clutch response is better, going over speed bumps and dips feels better.
    then ive put cages in after sub frame connectors and thats like 5xs better than the subframe connectors.
    the stiffer you can make the body of the car the better the suspension is able to work and control it.
  6. John W
    John W Member
    Walkerton Ontario Canada
    1932 Ford Roadster Hot Rod 1977 Maverick
    I have a 77 car and yes, the e brake assembly is in the way. Is there a suggestion on how to move this assembly or is there a unit from another car that I can use? I would like to use the Chassis Engineering connectors, but maybe there is another connector from a different manufacture that is better suited for the 77 model car. Open for suggestions.
    Thanks
    John
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Wasn't Joedirt making some? I would be interested in a picture showing how far below the rockers the Chassis Engineering connectors hang. They look like the would swallow up some of the ground clearance.
  8. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Don't know if this helps, 2 1/2 inches from the floorboard of the comet.
  9. RMiller
    Kennewick, WA
    They do hang low don't they? Thanks for the picture!
  10. John W
    John W Member
    Does anybody know if Joedirt is still making his brand of connectors? I sent him a PM a couple of days ago, but have not received a reply.
  11. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    dont forget about his monte carlo bar :)
    wish his SFC would come out though ..hes been quiet, or atleast I havent noticed any posts
  12. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    Yes, he was. I purchased a couple of sets from him, probably a year ago or so.
  13. John W
    John W Member
    This picture helps a lot. Thank you so much for posting it. I am now thinking I will have enough room to move the pivot around and run the cables between the connectors and the floor board.
    Thanks again.
    John
  14. safado
    safado Member
    West Phoenix, AZ
    Sorry to bring this tread from the dead, but I figured the info can be kept in the same place...
    So, besides home built, those are our only options for purchase? ( the Chassis Engineering or the Total Control/Alston chassis works?) Any pictures of these how the attach to the rear frame?
    From the Fox body gurus, like Maximum Motorsports, the SFCs should be the entire length of the front subframe.. or at least the most you can over lap the better..
    Does anyone make thru the floor SFCs for our cars?
  15. mav man
    mav man Member
    wi
    70mav
    Alston fit good and look good
