front coil and shock write up
Discussion in 'Technical' started by john T, Oct 19, 2010.
  1. BrianB
    BrianB Member
    1973 Maverick
    is the process the same for the rear? i have air shocks and want to know how to replace them..
  2. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    ill be doing this next after the cowls welded back up. i dont plan on torching the coil :D
    is the coil held by anything or will it come right out once compressed?
  3. PaulS
    Don't use air shocks on your Maverick/Comet - They will tear the top support out.
    The process of changing shocks is to un bolt the top, then the bottom. Install the new ones by connecting them at the bottom first then the top.
  4. rthomas771
    The Shop Manual says to disconnect the bottom first and connect the bottom last. Tighten the upper attaching nuts to 45—65 ft. lbs. and the lower attaching nuts to 14-26 ft. lbs.
  5. BrianB
    BrianB Member
    1973 Maverick
    yeah i know, theres air shocks on the car right now, so i want to put something else in, is there any type i should use or look out for?
  6. john T
    john T Member
    coalinga CA
    72 maverick grabber
    The KYB gas adjust ones where recommended by maverick man and i trust him quite a bit. theyre pretty inexpensive too
  7. john T
    john T Member
    coalinga CA
    72 maverick grabber
    i was replacing the springs and didnt have access to a coil spring compressor at the time. so i just compressed the spring by lifting the lca with a jack and heated up the coil until the coils started touching each other. be careful not to cut through the coil (im not sure what would happen but i have a feeling it may jump out)
    If you do use a coil spring compressor dont use an impact to tighten it up. DO NOT use strut spring compressors theres not enough room under our cars to use them properly(safely)
