Front coil spring question
Discussion in 'Technical' started by fixmer, Nov 27, 2004.
  1. HeLMeT 76x2
    HeLMeT 76x2 Two 76 Fords...!!!
    Vancouver, wa
    1 1976 ford 4-door maverick. 1 1976 ford econoline 100.
    .... fomodave.... wasn't this thread about lowering the front end? lol..
    and... i did the v-8 swap... so i just need to cut a coil and a half off my 6banger springs?
  2. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    The post by fixmer was that he liked the "raised up look"......... I would not cut a coil off a 6cyl spring to lower car when you can buy new springs with the correct rate already cut for less than $100. New spring vs old spring with wrong rate and many miles.JMO
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Was your 6-banger a 250? If so, the springs are the same as those in V-8 Mavericks. If they are from a 200, I wouldn't cut them, as they should already sit lower with the V-8 installed...
  4. HeLMeT 76x2
    Vancouver, wa
    no mine had the 250 in it, and it just sits WAY to high for me i want to put 40 or 50 series tires and have it sit so that the fender is just 1/4th in above the top of the tire... i'm running 14" cregars btw
  5. HeLMeT 76x2
    Vancouver, wa
    and sorry fomodave, i didn't read the post correctly, my apologies.
  6. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Here is a pic of the aftermarkets 550lb lowering springs next to stock V8 springs. While they are a LOT shorter on the bench, they lowered the car about an inch.
  7. HeLMeT 76x2
    Vancouver, wa
    wow that looks like it'd lower it alot more than an inch...
    how many coils should i cut out of mine? i've got the stock inline 6 250ci springs.... and i'd like the rim of the wheelwell about 2 inches above the top edge of the rim...
  8. T.L.
    T.L. Banned
    Southern Colorado
    Cut one coil...
  9. HeLMeT 76x2
    Vancouver, wa
    that'll give me the desired look? alrighty! i hope yer right...if yer wrong... i'll have to cut some more! haha either way nobiggie:) from the looks of it tho it almost seems like i need to drop 4 inches... 1 coil will do that?
  10. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    1 should be right......I cut 1 1/2 off mine and its too low.
  11. HeLMeT 76x2
    Vancouver, wa
    i guess ur right, cuz when it compresses it'll move down even further than that because the springs now weaker, is this going to make my car ride like total crap?
  12. Craig Selvey
    Putting a little more air in that tire should fix that problem.
  13. T.L.
    T.L. Banned
    Southern Colorado
    Cutting 1 coil will not drop it 4 inches....and 4 inches is WAY too much. If you really want it that low, you need drop spindles. That thing will never align properly if you cut the springs enough for a 4-inch drop. Also, your tires will rub, unless they're real skinny and have the right back-spacing...
  14. HeLMeT 76x2
    Vancouver, wa
    should i cut 1/2 a coil and use the shelby mod/drop thing i was reading about in here?
  15. T.L.
    T.L. Banned
    Southern Colorado
    Sure, if you can afford it, I say go for it.
    I cut one coil from old springs and it dropped the car a little more than I wanted it to. If I had it to do over, I'd go with new springs. You can get 'em for $60.00 a pair...
