front end rebuild list of parts
Discussion in 'Technical' started by Rogue302, Jun 1, 2017.
  1. Rogue302
    Rogue302 Member
    Massachusetts
    Hey guys,
    Im going to replace most of my front end steering/suspension components on my 72 maverick with manual steering.
    I've come up with a list of moog parts and just wanted to double check and make sure im not missing anything.
    -Upper control arm (assembled with balljoint, shaft and bushings) #RK621369 $68.75 x2
    -Front strut rod bushings #K8157 $39.04
    -Front sway bar bushings #K5227 $6.97
    -Front sway bar end link -heavy duty #K6630 $10.62 x2
    -Outer tie rod end #ES387R $25.71 x2
    -Inner tie rod end #ES387L $63.78 x2
    -Upper control arm alignment kit #K8243A $20.06 x2
    -Lower control arm (balljoint & bushings) #CK8123 $60.14 x2
    -Idler arm bushing (manual steering) #K8094
    http://www.moog-suspension-parts.com/products/ford_maverick_1972
    I know its missing the pitman and idler arms and adjusting sleeves. I was thinking these could either be reused or just sourced elsewhere.
    Anything im missing?
  2. 71gold
    spring perches... spring insulators
  3. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    I would definitely recommend roller spring perches, they are pricey but MAN do they make a difference in ride quality!
    canuck222 likes this.
  4. Tannersg1
    Tannersg1 Member
    Classified
    If I were you I would call Moog about that upper control arms. When I called in reference to them the guy on the phone says it would be best to rebuild the original ones. Something about them being cheaply made. But it's your call...
  5. mojo
    I installed Moog UCA last spring; I don't have any issue w/ them. Comparing them w/ the OE units, I don't see any visual or weight difference. If there is any significant difference it's not obvious. Also, I agree w/ Mad Goon --- roller perches are pricey, but do make a difference in ride quality.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
  7. mojo
    I got a set of those too. I did my entire suspension & steering replacement. I wish I had got a set of lower control arms w/ roller bearing too. If I ever do any other work to the suspension will get a set. For now going to ride/cruise and enjoy what's on the car now...
    https://www.pacificthunderperformance.com/collections/1970-1977-maverick-comet
  8. x72COMETx
    x72COMETx Member
    Vallejo CA
    I no what you mean, I rebuilt my suspension front to back last year and I wish the one peice LCA was available
