Front end rebuild question
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Apr 15, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    rome georgia
    When rebuilding the front end do I need to just snug everything and THEN tighten it while its on the ground with the full weight on it?
    All new parts. The only thing I have tightened 100% is the new upper control arm and the spring perch.
  2. Doug
    Doug Member
    washington state
    71 maverick grabber
    I tighten everything before setting down . the only things they recommend tightening after its down is you rear leaf spring mounts
    Mav_Max1972 likes this.
  3. Krazy Comet
    The lower control arms should be tightened with weight on wheels. Centers travel point of bushing between loaded and unloaded.
    Shorty likes this.
  4. dyent
    dyent Member
    vancouver bc
    He will be fine doing what he mentioned, will have to take it in for alignment anyways and more than likely, adjustment will be necessary on lower control arm, so shop will loosen and adjust cam/bolt........
    David
  5. Doug
    Doug Member
    washington state
    71 maverick grabber
    Krazy comet is right forgot that one
