Front Speakers
Discussion in 'Audio' started by Stews72s, Aug 17, 2009.
  1. mbg1973
    mbg1973 Member
    MARIETTA, GA
    1973 MAVERICK 2DR
    i have 6 or 6.5 in round speakers in my kick panels and 6x9 in in the back dash and it sounds pretty good but i would like to put a speaker back into the dash so that all the sound up front isnt coming from the floor
  2. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    In the kicks, nothing fancy. Sounds good. Cant remember if they are 5-1/4 or 6-1/2 inch.
  3. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    ^those look like 6.5's,
    I've got 5.25 in the kick panels and they fit like there factory speakers,but i plan on upgrade'n to 6.5's there too.......
  4. Jeff S
    Jeff S Member
    NoVA
    none
    If you remove the center duct and move the duct housing out the way you can get to the speaker from there, thats how I removed mine, but its a job...lol
    I was going to put mine in the kick panels, but the plastic is so brittle I know if Id try it it would just fall to pieces.
  5. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    ive got 6 inch
  6. CaptainComet
    If mounting speakers in the front kick panels, the cars prior to 73 have different sheet metal behind them. You might need to trim a bit. I installed 4.5 up front, attached to the kick panels themselves. Had to make a small amount of magnet clearance.
    Cars from 73-on have provisions for speakers stamped into them. Some kick panels from later cars have factory speaker grilles also, but I am not sure if they work completely with the earlier tray-type dash.
  7. david_h_30170
    david_h_30170 Member
    Roopville,Ga
    1973 2 door v8
    I just bought a Sony xplod at Wal-Mart , came with 2 ,6- 1/2 speakers and 2 6x9 speakers for $90 bucks. I hope install them this weekend maybe they will sound ok.
  8. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    i plan to buy the same system also mostly just to get some music in my car and get it installed before i start putting alot of money into it. let me kno how that goes cause its gonna be a couple months before i get started on mine
  9. bmcdaniel
    If you do a search...
    I put 6x9s in the doors, lower front corners.
  10. mojo
    I put 5.25 in my 73's kickpanels. I like that better for stero seperation than spkr's in the dash grille. I had cut-outs in the metal. My spkr's depth caused them to hit the metal so I had to use foam spkr cones to bring them off the metal.
    If it's a DIY install, I wud'nt go over 5.25 unless I was looking for a installion challenge - If I was having i t professional done I wud go for whatever they cud put there. I suppose it depends on what caliber of sound one is trying to achieve. :tiphat:
    img_0019_original.jpg [​IMG]
  11. doobster
    doobster New Member
    Ohio
    1977 Ford Maverick
    looking to buy speakers for the dash and rear deck in a 77 maverick, anyone know the specs on those?
  12. Craig Selvey
    6 x 9 rear. 5 x 7 front dash.
  13. jdproper37
    jdproper37 Member
    Fargo, ND
    1977 Ford Maverick 4dr
    I'm installing 4 1/2" in the front kick panels and 6x9's in the rear. If you take off the kick panels there should be a place to mount the smaller speakers.
    Jason
