Front wheel backspace
Discussion in 'Wheels and Tires' started by Ivan Colesnic, Jul 9, 2015.
  1. Ivan Colesnic
    Ivan Colesnic Member
    1973 Ford Maverick
    Hey guys I need a front wheel and I am wondering what backspace I need to run. I am running a 17 inch wheel because of the brakes. Will a 17x7 work with 4 inch or 4.5 inch back space? I think I want to run like a 225/45. I might run the same wheel in the back.
  2. Crazy Larry
    Crazy Larry Member
    Sanbornton, NH (originally from Colorado)
    4" to 4-1/4". You can run less backspace but you would need a narrow tire.
    4-1/2" will rub the upper ball-joint.
  3. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    Is that the same with a 15 in rim also... 4 - 1/4 B.S. ??? For the front?
  4. Crazy Larry
    Crazy Larry Member
    It's for any diameter wheel. I have found that with a 7-inch wide rim, 4" to 4-1/4" backspace works very well on the Maverick. You can run a 3-3/4" backspace on the rear without problems.
    I actually ran a 3-1/2" backspaced wheel with no problems, but that was a 6-inch wide rim.
  5. mjm0395
    mjm0395 Member
    Everett wa
    Thank you... that was for the front correct?
  6. Crazy Larry
    Crazy Larry Member
    Yeah.
  7. Cometman97
    Cometman97 Member
    Sacramento, CA
    1972 Mercury Comet 4-door 302v8
    Hi Larry, Could I run a 15x7 rim with a 3 3/8" backspace front and back? With a 245/60r15? Thanks!
  8. Crazy Larry
    Crazy Larry Member
    What wheel has a 3-3/8" backspace?
    You can run a 3-3/4" backspace with a 245/60 on the rear, but the fronts will likely rub on the fender when turning corners. 4-inch is just about ideal for Mavericks in my experience. 4-1/4" on the front if your car is lowered.
