Front windshield gaskett
Discussion in 'Technical' started by blugene, Nov 9, 2009.
  1. blugene
    Couple more things. I only had to clean sealer from the bottom of the frame up about 2 inches on the sides. Is that normal? It was the factory glass that was taken out as far as I could tell.
    Does the glass sit on some small stands close to the corners?
  2. Mavman72
    Yes and...yes
    My blue mav (original glass) had sealer half way up the driver side and all the way up the passenger side...
    The little stands keep the glass from setteling down too far as it all ages.
  3. blugene
  4. rthomas771
    I never seen it done that way.
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
  6. Mavman72
    This is also a popular method.Problem is there are a plethora of methods and practices Gene.No one of em is right or wrong just different approaches to the same job.The way I described has worked well for me on many occasions and isnt as messy as other methods.I havent had any come back for leaks soo...research it and find the method you feel comfortable with and go with it.You cant go wrong as long as you seal it all well.Good luck Gene!!!
  7. blugene
    Thanks guys. I bet I can do it myself if I have to. I just need to find some of that sealer.
